TobyJ66
About TobyJ66
TobyJ66's Achievements
  1. Good Morning Folks, I have a 1st gen (2012) Edge with the 2.0 EcoBoost engine. Does anyone have instructions or a video on replacing the radiator? Before you hit me with the “YouTube is your friend”, “If you have to ask, send it to a mechanic”, or “do you know how to use Google” comments, just know that: - I am quite mechanical: * I am your standard GenXer and I have actually replaced many a radiator in my day and worked on a multitude of different projects. - I have a lot of tools and I know how to use them: * Not only do I have standard and metric ratchets, wrenches, and sockets, I also have impacts, air compressors, diagnostic tools, etc. - I have googled this topic till the ends of the earth: * There are guides out there for the Ford Edge with the 3.5-liter V6, but I have not been able to find any for the 2.0 EcoBoost. - I have YouTube'd this till the ends of the earth: * Same as Google. I can find 3.5 videos all day long, but no 2.0 EcoBoost for the first gen. - I have scoured the forum sites: * Same results as Google and YouTube. - Because of the electronics involved in these newer cars, I do not like to go in blind: * I don’t just want to start snatching on plugs and harnesses all willy-nilly. - I have brought it to a mechanic: * They want 600 bucks and I definitely don’t have it. Any help and/or instructions y'all have for me would be greatly appreciated. Love y'all.
  2. Team, I have a 2012 SEL with the 2.0 ecobost engine. Not too long ago I had to put the car in the shop to have water outlet valve, Coolant Bottle cap and the heater hose (Part-12/99 CT4Z*18C553*) replaced. The vehicle ran great for about a week. Now its slow to accelerate, especially when it warms up. I hooked a code reader up to it and I got the following codes: P0012 P0299 P0012(00) P0299(00) P0012(00) P0299(00) What is the most likely problem and is this something that a DIYer could fix? I'm definitely new to forum sites.
  3. @1004ron I'm actually seeing coolant on the ground in two different locations. Near the firewall and up by the radiator. I just cant see the actual leaks.
  4. @1004ron I actually purchased it like this last year. I brought the car to three different shops because I changed the brakes and shortly thereafter the break pedal would slowly start to go to the floor. The first shop changed out the master cylinder twice but wouldn't touch the heater hose. The second shop changed out the master cylinder a third time but wouldn't touch the heater hose. The mechanic informed me of the heater hose; he said that he did not change out heater hoses on this particular vehicle. The third shop changed out the brake booster and the abs pump; however, none of them wanted to mess with the heater hose. I think I have a crack in my radiator also. All of these shops are licensed and bonded. All LLC. Like real shops. no shade trees.
  5. @1004ron where is the air vacuum pipe located. The serpentine belt is definitely inside out.
  6. How's everybody doing? New to forum sites. I have the 2.0 ecoboost. The heater hose is cracked. Its gotten to the point where I am having to put radiator fluid in it once a week. I want to try and change it myself; however, I cannot find the location of the heater hose. When I googled it, three different hoses showed up. I took it to a local shop and the mechanic told me that the intake has to be removed to change it and that he does not do heater hose changes on that specific vehicle. Does any one have a diagram or anything like that? Also how hard is it to change the radiator.
  7. Mine has been doing this since I purchased it (used).I couldn't figure out what it was.
