vyzr
Everything posted by vyzr
  1. Hmmm I had originally uploaded from my iPhone.... Let me convert it from MOV to MP4 and re-upload. @Wubster100 Hopefully you can see this? IMG_7493.mp4
  2. I apologize, @dabangsta, I totally mucked up that post and put the INCORRECT bulbs. THESE are the bulbs I got that CORRECTLY fit my 2019 Edge SEL https://www.amazon.com/Resistor-Extremely-Blinker-Replacement-Upgraded/dp/B09S9WGSWY The ones I incorrectly posted above https://www.amazon.com/AUXITO-7440-Resistor-Blinker-Replacement/dp/B0CLP6N7SX?th=1 were the ones I had originally ordered (due to the user manual and Amazon stating they were what I needed) and DID NOT fit. So yes, it DOES take the PWY24W bulb like the Fusion. Sorry for the con"Fusion"... <--- see what I did there? I'm cool like that.
  3. Just wanted to do a follow up post, I got the turn signals and installed them. These are the ones I purchased: https://www.amazon.com/AUXITO-7440-Resistor-Blinker-Replacement/dp/B0CLP6N7SX?th=1 edit: https://www.amazon.com/Resistor-Extremely-Blinker-Replacement-Upgraded/dp/B09S9WGSWY They are comically bright compared to the stock bulbs. I wouldn't know how to describe the difference in lumen output, but the stock bulbs are kind of a soft, hard to see glow, whereas these new LED bulbs are akin to laser beams, seemingly at least twice as bright as the stock ones and just pierce the very fabric of your soul when you stare at them. No hyperflashing either! Here's a video at night. IMG_7493.MOV
  4. This is great info, thank you so much! A few weeks ago I actually upgraded to an H7 AGM Odyssey battery after the stock 2019 Motorcraft battery failed, and I used Forscan to update the BMS info to an "02" battery. I'll have to disable hyperflash as well if the built-in resistors on the bulbs don't work.
  5. @1004ron Oh my gosh, thank you so much! The exact bulb! I did a search for that part number and the LED replacements showed up on Amazon! The base of the bulb appears to be the exact same. https://www.amazon.com/iJDMTOY-360-Degree-Compatible-European-Vehicles/dp/B00QN1WAPS/
  6. Hi everyone, One of my front turn signal bulbs burnt out on my 2019 Edge SEL. I went on Amazon and it said a 7440 bulb would be the replacement, so I ordered a pair of 7440 Yellow LED bulbs with built-in resistors. When I tried to change them tonight, I twisted the socket out, and then bulb that pops out of it is NOT a 7440 bulb. So I checked the user manual and it says it requires a WY21W bulb, which upon further investigation, is the same base as a 7440 bulb. Anyways, the bulb that's in my turn signal socket is some weird bulb I've never seen before and there are no identifying marks on it. I did some forum searching and found out that there are possibly three types of Edge SEL light housings, so maybe mine are the weird type? Would anybody know what this particular bulb is? Thanks in advance!
