Yurez
Everything posted by Yurez
HOW TO add OEM Remote Start (2015+)
Yurez replied to colinc755's topic in Accessories & Modifications
Good afternoon. What year is your car? Can you post the dashboard configuration?- 45 replies
- guide
- remote start
To program the keys you need a new RTM. There is no point in saving the configuration of the old Rtm.- 45 replies
- guide
- remote start
Based on the part number, I determined that it belonged to a Mustang. then I found a Ford Edge about the same year using the VIN code and used the files for the firmware- 45 replies
- guide
- remote start
I can't connect the charger. I connected power to pin 1 and charge enable to pin 3. Ground at 5 pins. Charging doesn't work. Can it work without being connected to the car.
Thank you very much for your help. you are the best as always
Does anyone have a wiring diagram for wireless charging? m1pt-19j235-aa Ford edge 2020
Replacing the Ford EDGE instrument panel
Yurez replied to Yurez's topic in Accessories & Modifications
There remains a small inaccuracy. The opening of the rear door is not displayed on the display; there is something else that can be corrected in the configuration? -
Maybe someone will find the final configuration of the dual-screen dashboard for the 2018 EDGE SE useful. Later, BLIS radars and heated mirrors will be installed. Thank you very much Haz for your help! -
what value should be set and how is it related to blis? -
In order to disable the error about loss of communication with the parking assistance module, you need to set 0 in cell 720-01-01 ХХХХ-ХХХХ-Х0ХХХ. The slob still has one error, U0103, loss of connection with the GSM module. Help me figure out if the shifter type is set incorrectly? -
From personal experience in installing remote start and installing a new RTM unit. My 2018 EDGE had an RTM installed from a 2015 MUSTANG and naturally the wheel pressure sensors stopped working. I updated the RTM to the latest firmware from a 2020 machine. And retrained the pressure sensors. After that everything worked.- 45 replies
- guide
- remote start
Many thanks for the help. Here is my configuration. I still have the problem of displaying the opening of the trunk door on the dashboard and loss of communication with the parking assistance unit. -
Good afternoon. The 2018 Ford EDGE 2.0 has replaced the single-screen instrument panel with the dual-screen instrument panel of the 2020 Titanium model with a power rear trunk lid. I don’t have one and an error appeared in the IPS for loss of communication with the rear door unit. Tell me how to correct the instrument panel configuration using Forscan.
On my Ford EGE 2018 2.0, for the remote start system, I installed an RTM unit from a 2015 Ford MUSTANG, after which the TPMS system stopped working. In the BCM settings, the type of sensors was set to MY09 and MY15. Only the MY09 sensor works. I have MY15 sensors installed in my wheels. How to be. Maybe update the RTM module? Sorry for my English, I'm translating through a translator. RTM - Radio Receiver Module Part Number: FL3T-15K619-CB Calibration level: FL3T-15K619-CB (last known: FL3T-15K619-CC) Strategy: FL3T-14G090-AB
Installation of a seat in EDGE SEL from TITANIUM
Everyone who will install seats from TITANIUM can do this according to the scheme that I posted. Seat climate will connect later. I'll post the diagrams separately. -
thanks a lot for your patience and help. but I still do not see the connection diagrams for DSM and SCME blocks on the general diagrams. there is no wiring diagram for the seat controls. thanks again for your help. how power is connected to the blocks and the data bus. -
I have two different units located under the passenger and driver seats -
thanks for the diagrams, but what you show is this unit is located under the driver's seat and the C311 C312 adapter cable between the passenger and driver's seats. -
please look at the passenger seat, the climate control unit is installed like this as in the photo. Unfortunately, I didn't see anything like that in any of the diagrams. -
thank you very much my friend -
thanks for the diagrams. Do you have schematics from the newer EDGE may 2019. I have two control units under the driver's seat and under the passenger seat. -
I translate messages through google translator, so there may be inaccuracies. I wanted to say the front and rear seats from the Titanium model. -
Yurez posted a topic in Accessories & Modifications
I purchased a restyled seat from TITANIUM and I want to install it in EDGE SEL 2018 who has Climate Controlled Seats connection diagrams. Thanks in advance to everyone who responded.
