sid660raptor
About sid660raptor
288 profile views
sid660raptor's Achievements
  1. O yeah and the black shrink like tubing that goes around the crankshaft position sensor is missing n touching the motor,does that matter??? It still has the metal or foil around it jus missing the black stuff
  2. O yeah and the black shrink like tubing that goes around the crankshaft position sensor is missing n touching the motor,does that matter??? It still has the metal or foil around it jus missing the black stuff
  3. Wow thats a lot but I'm learning as I go,prior to reading this I used the multimeter to check from the PCM to the camshaft position sensor both of them and on the own I got 0.5 on one and 0.4 on the other and I changed the csps that's on the bk side under the intake....with no difference on the vehicle
  4. So I ended up changing the csps on circuit A, or the 1 under the intake kinda!! And the same thing..it will idle for 15min jus fine then I get 2 codes now...wtf is going on Thank u..I really appreciate it
  5. So I recently changed my water pump which was hell got my truck back together started it up and it started having a Mis like right away.. hook up the scanner it gave me P0 340 camshaft position sensor a circuit malfunction I changed two of them just to see and nothing different I checked my power source I checked out on my front coils see if they're getting power they were getting power but in between the camshaft position sensors it loses power somewhere does anybody have a wiring diagram so I can check I just plugs in between there like where they go to like there's two wires that go underneath the intake to somewhere it's right next to camshaft position sensors I just can't find a wiring diagram to like help me
  6. Also everyone say to replace timing chain tensioners,can I get away without replacing them rn??
  7. I got 1 finally,next problem is where are the exact location of power steering pump mounting bolts located??
  8. I need that tool are you will to loan it 2me if your near west Michigan??? I'll pay to use it
  9. Does any1 around swm have a camshaft holding tool for timing alignment??? If your willing to let me borrow I'll give u 20 bucks,I' have my 08 edge apart changing the water pump n it sux..lol
