Kpcrn6
Everything posted by Kpcrn6
  1. I have 2017 and getting the charging system fault. Alternator only measuring 13 volts. I cannot open the document but I assume it is best to go at the replacement from under the car.
  2. Had to replace starter today. It was a hard job. You have to perform the work from the top. Remove the two nuts from the starter to the engine block first. You can then tilt the starter to allow access to the electrical wires. Take the 13mm and 10mm nuts off and remove the electrical box and now you can pull the old starter out the top.
