Summers22
Everything posted by Summers22
Parking brake limited function
Summers22 replied to sjskowron's topic in Brakes, Chassis & Suspension
Need some thoughts, got the dreaded warning messages on the dash about parking brake malfunction after driving in the rain today. So far I have a DTC, C2007. That's the right actuator. I attempted to put the vehicle into service mode, but that is not working. It is not the body to motor harness as it works on the driver side actuator and it's not the passenger actuator itself, as I removed it and tested it on the driver side and the actuator cycled perfectly. I assume this means there is a break in a wire somewhere between the driver and the passenger actuator. I will do some more digging tomorrow, but a couple jumper wires may be made and installed so I can get it back on the road. Hard to see how the wiring is routed as it looks to go up into the body on both sides, so I may remove the spare and see what I can see. Anyone have this dtc and the harness and actuator are fine? Quote -
New 16-19 ebony leather driver seat back and bottom replacement covers
Summers22 replied to Summers22's topic in Classifieds
Willing to do $100 plus actual shipping -
Nobody has a torn seat they need to make like new for cheap? -
Lets get these moved! $100 plus actual shipping -
My 18 Titanium has the 3.5 n/a and I absolutely love it. Much more power than my 14 Flex had with the same motor. I haven't looked into the gearing, but this Edge is much more nimble.
Thank you, I am hoping someone here needs them eventually -
Price reduced, $200 for both, make your seat new again!!!! -
Selling a replacement set of leather for a 16-19 Edge. Ebony leather seats for the driver side. This is the back and bottom OEM replacement covers. I paid over $700 for them and we decided the 2 rips in the existing seat could be repaired cheaper by an upholstery shop. I'll get pics of OEM parts numbers and actual covers up tomorrow. $100 plus actual shipping for both!
So is it okay to run H11 HID in the low beam spot if DRL is disabled through the cluster?
What to turn off in automatic carwash, 2018 Titanium
Summers22 replied to Summers22's topic in 2017-2018 Edge & MKX
I have them disabled already (before the carwash incident anyway). I am starting to wonder if water got in a connector somewhere. -
So I am a F150 guy, the XL/STX type of guy. Got my wife a 2018 Titanium with all the bells and whistles. Well she went through an automatic carwash and the thing apparently went nuts, sensors, warnings in the dash and center stack went crazy. What setting needs disabled for that to not happy again? Yes I know automatic carwashes are bad for paint.....you can lecture me on that later. Thanks for the help.
Looking to see why an extra hose was added to the nipple of my upper intake manifold of my 2018 3.5 Titanium. Just purchased the car and the hose is there, but no can. Mechanic sees no reason why it's there or has no idea of why it is there. If you have one, please post pics as all the tubing is there for me to add my own if I so wish. This was an original California car, I though maybe it was an emissions set up of sorts.....
Summers22 replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Thank you, much appreciated! -
So thats a no, thanks. -
For you guys doing Forscan changes, do you have a spreadsheet somewhere on this site? I am a member on F150forum and we have an EXTENSIVE spreadsheet. Thanks -
New member, but not new to Fords or Forums. I just bought the wife a 2018 Titanium with the 3.5 N/A. I was doing a inspection of fluid levels today and stumbled upon this. There was a length of hose added to the nipple on the upper intake manifold, right behind where the throttle body mounts. It loops around over the top of the brake fluid reservoir. The hose also has a t valve that is capped off. I sent a picture to the dealership I bought it from and their mechanics have never seen anything like it. The car did come from California, so I wonder if this had anything to do with making yearly smog testing easier??? I only just saw it because I was checking all fluid levels before a trip and the brake fluid was slightly low. What caught my eye was the use of a standard run of the mill hose clamp, that Ford doesn't use. After looking at pics on the internet, it was determined this hose was added. Anybody know why? Thank you, Jon
