Need some thoughts, got the dreaded warning messages on the dash about parking brake malfunction after driving in the rain today. So far I have a DTC, C2007. That's the right actuator. I attempted to put the vehicle into service mode, but that is not working. It is not the body to motor harness as it works on the driver side actuator and it's not the passenger actuator itself, as I removed it and tested it on the driver side and the actuator cycled perfectly. I assume this means there is a break in a wire somewhere between the driver and the passenger actuator. I will do some more digging tomorrow, but a couple jumper wires may be made and installed so I can get it back on the road. Hard to see how the wiring is routed as it looks to go up into the body on both sides, so I may remove the spare and see what I can see. Anyone have this dtc and the harness and actuator are fine?
Quote
