Thanks for the video! It seems the brushes wear all the way down and then lose contact with the commutator.
If the brushes are desoldered and replacements resoldered properly should the fix be reliable? I guess it would be like a remanufactured Ford fan.
He uses replacement brushes marked FM-312 but they don't seem available anywhere. The dimensions look to be 6mm x 7mm x 20mm. Does that seem right?
These on Amazon should be the right size but a different style. Cutting the copper wire from the gold clip would seem to make them like the OEM brushes. Would the length and gauge of the copper wire be an issue?
https://www.amazon.com/uxcell-Carbon-Brushes-Electric-Replacement/dp/B07DYW3MG6/
