ImSuperCereal
Everything posted by ImSuperCereal
  1. Hi everyone, So had to replace engine due to the terrible design of the engine causing leaking into the cylinders as I’m sure a few of you have. I’ve ran into a bit of a conundrum and I just want to ask on here if anyone had run into the same issue after engine replacement. I first noticed the issue when it smelled like coolant in the cab so I checked under the hood and indeed the coolant level was low. After some research I found the “TSB” (should have been a recall but you know how dealerships are sadly) I took it in and it was confirmed so long block replacement was done. The issue is, it’s been multiple months and I still smell coolant on start up. Thought maybe it was cabin air filter, so I replaced that to no avail. Has anyone experienced the same issue? Just wondering.
