dabangsta
I have 3 Fords that are daily driven. 2012 Fusion with gear shift lever (and gated for manual +/- shifts) 2016 MKZ with row of buttons to the left of the infotainment display (and paddle shifters on the steering wheel) 2019 Edge with the dial shifter (S mode button, no paddle shifters because FWD, but would love to add them) It took a bit to get used to the gear shift lever (I came from a Grand Marquis with a column shift) but not too long, as have had floor shift automatics before. It took a bit longer to get used to the dial shifter in the Edge. Now if I haven't driven it for a while if I am turned looking behind me I go the wrong direction, so I go to Park instead of Drive after backing up in Reverse. Still getting used to the row of buttons on the MKZ. It isn't intuitive and I still have to look at it. I won't be doing any J Turns in it anytime soon. The last 2 vehicles I don't shift to park. I press the Start/Stop button and it auto shifts to Park. I like that.
I don't have vented rears, I have the solid smaller rotors, my fronts are inverted hat like the non PP ST rotors. This shows pad wear (still have some of the bevel left), the friction area (they look grooved, but they are smooth, and nothing smeared), and the hat/cooling fins (some brake dust, some water spots, I don't think any rust): front: rear:
I will have to see how the coated rotors look on my 2015 Fusion that is driven in rain, snow, "salted" roads, but the ones on my Edge that lives in the desert are still shinely coated and no signs of rust. The wear pattern is great. One small groove I can barely feel with a finger nail. They still take a beating and don't overheat/shudder on long down hill descents, or high effort short stops (not quite emergency stops, but close). I don't have discolored lines/marks like you do in that image. I only have 31,000 miles in the 17 months on it since replacing the brakes, I haven't recently checked the pad depth. I guess Z17 are low dust ceramic, so on my 2019 Edge (non ST) I did the same rotors and pads. I got the Z23 (carbon fiber/ceramic) pads and the same geomet coated rotors for my 2016 MKZ. I haven't installed them yet. Since I drive my MKZ more and am the more aggressive driver of the household, I tend to go more for the drilled, slotted, carbon metallic pads.
door ajar issue - 2013 SEL
dabangsta replied to mdjbhouse's topic in Alarms, Keyless Entry, Locks & Remote Start
Super common issue. There are a multitude of ways to either fix it, or disable it. I am surprised a google search for "ford edge door ajar" didn't link to more than one thread here. Once you figure out what door it is, it can be replaced (the latch) or some go so far as to just break out the switch so it never works, which I would find annoying, but not as as annoying as lights on all night or alarm sounding, or errors while driving. -
I would rip it out in a second if I could get rid of the eject button. It is always being touched and pausing whatever media is playing while it decides if there is a disc or not. I thought it would be easy to get to and disable when I had the center stack out, but it wasn't, and it seems to be logic and not a stand alone circuit to snip. I was happy when my 2017 Escape and 2019 Edge didn't have them. I did find my old "driving CD's" I burned so many years ago, but with 5 or 6 streaming audio selections, XM, and USB drives, I can deal not using a CD ever again.
2019 Edge isn't going anywhere, except vacations. Tried to get some pictures of the flipping of green to gray, but it is just green.
My 3.5 powered Fusion Sport had the water pump let go at 159,000 miles, and filled the crankcase up with coolant and over heated, it a very short period of time. Not sure if it is fixable for reasonable or not. So I went to look at an MKZ (and they had 2 MKX's that I wanted to check out as well). Not many of them around, and the 2017+ with the 3.0TT are pricy when they come up. So I looked at 2013-2016 with the 2.0 (also available with the 3.7, no thanks). This 2016 MKZ Reserve with the Technology Package and moon roof fit what I was looking for and price. I didn't want a moon roof because of how much head room they take, but not bad. Still warming up to the color, Guard Metallic with Cappuccino interior. 95,000 miles. It is missing some things from my 2019 Edge SEL, like stop and go cruise (it has adaptive cruise, but at 12 mph it turns off) and lane centering. But it has a lot more options. Reserve includes: Ambient Lighting HD Radio™ Accent Light (in Headlamps) Electrochromic Exterior Driver Side View Mirror PowerFold® Side View Mirrors Daytime Running Lamps – Configurable Power Tilt/Telescope Steering Column Leather Seating Navigation with voice recognition Blind Spot Information System w/Cross-Traffic Alert Power Decklid with Soft Close Cooled Leather Driver and Front-Passenger Seats Heated Steering Wheel Heated Rear-Seats 110 V Powerpoint Embedded Modem And the tech package adds: Adaptive Cruise Control and Collision Warning with Brake Support Active Park Assist Lane Keeping System Forward Sensing System Auto High Beams Rain-Sensing Wipers Already swapped SYNC 2 to SYNC 3, the 3G TCU to a 4G TCU, the spark plugs, air and cabin filter. Next up is coolant and transmission fluid, cleaning up some chips and the exhaust bezels (like the Edge ST, part of the bumper).
2024 Edge USB Outlets Power Only
dabangsta replied to Ronno6's topic in Audio, Backup, Navigation & SYNC
The manual does say: So yes, they are switched, and not always powered. https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=9611&languageCode=en&countryCode=USA&moidRef=G2127957&Uid=G2143359&ProcUid=G2134795&userMarket=USA&div=f&vFilteringEnabled=False&buildtype=web -
I did mine at 96,000 miles because my rears were worn down to 2-3mm, and it was pretty easy to get them chattering after hard stops (adaptive cruise and mountain passes). the fronts were still over 8mm, could have gone a lot longer before replacing them, but I had ordered the parts and also was upgrading my smaller FWD rotors to larger ones. For some reason I skipped painting the calipers, I always do them on all cars I have owned, but didn't feel it with this one.
Order guide for 2024 shows Oxford White as code YZ, available on the SE, SEL, and SAP (available on the SEL). The door sill sticker shows WB? I don't recall seeing any year Edge available in Performance White.
Even though the owners manual shows there might be both, how many USB ports do you have? The ones at the base of the center stack in the center console are data. I don't think you have any others any place else, not even the center console bin, back of center console, or cargo area. It states that if it has the USB symbol it is data, and a battery symbol it is charge only. -
Nautilus 2.7 Has Woken Up!!!!
dabangsta replied to jbrumley1's topic in 2019-Current Edge & Nautilius
It was very common on mid 2000 to 2010 legacy cars, my 2000 Grand Marquis had a MAF and an IAT separate, but 2003 it was IAT attached to the MAF sensor module. But on a vehicle without a MAF? Or anything not legacy? -
dabangsta replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
While I know that is close to the quotes from brake places, I squirm every time I see that price, after having done my own (and upgrading to the larger AWD brakes for my FWD vehicle) for...$388 (4 coated premium rotors, all pads, all bushings, 2 larger front caliper mounts). $280 without the caliper mounts. Probably didn't have any more required waiting until they were dead, should replace rotors anyways. -
Those two tires are basically the same diameter and revs per mile, so as long at the wheels are up to spec as well (offset, width, etc) then they would be fine.
They are not all the same! There are some many factors. While diameter is important, what that diameter does, how many revs per mile, is sometimes easier to see the differences. 2 randomly picked tires that tire rack shows the actual specs for (not the generated from published sizes). I don't think you understand section width versus tread width, and how that can affect the ratio (that 60 in this example which is a percentage).
Interior Lights Never Come on
dabangsta replied to PaulTexas's topic in Interior, A.C., Heat, Interior Trim
Did you try all doors to see if the light comes on from any of them other than the drivers? If the door is open does the dash say the [which door] door is open? The switch is part of the latch and fails often, and is bypassed frequently so that it doesn't always say it is ajar or not allow it to be locked. -
While there are 3 possible configurations for your SEL (standard 6 disc with 4 speakers, SYNC added, or navigation premium sound with 9 speakers), SYNC can require a hard reset, which is done either by removing the fuse (#3 under the dash), the radio (fuse 28), I haven't had a vehicle with stand alone satellite module (fuse #13), or pulling the negative battery cable. I don't know how accessible the fuse panel in yours is, but in my 2012 Fusion, it is easier to pull the battery cable (for ~20 seconds, and turning on the headlights to be sure to discharge power, often if I don't do that, it will not reset, and I can tell because I don't lose time or radio presets). If it has never worked, as suggested, a master reset would also be a good idea. Get rid of the previous owners phones (if it has SYNC/Navigation), do you have a Sirius/XM account? Are you expecting it to work, or hope it has lifetime, or the previous owner left their account active?
Add remote start to 2013 SEL
dabangsta replied to 31bullitt16's topic in Alarms, Keyless Entry, Locks & Remote Start
I love the MPC remote start in my 2015 Fusion. I have never seen these be an issue, other than the older ones and using lock/lock/lock makes the horn honk. I hope you find your way back after it all and post what works for you. The range for those keys/fobs isn't great, it is another limitation that either of these solutions (new IKT with 5 buttons, or aftermarket add on without including longer distance fobs (which they offer)) solve. Mine can't always work through all the walls to the garage, or to the parking spot on the road. -
Your SEL has the IKT (the key start, key has the remote fob on the head). There are aftermarket remote starts that are easy to add that use the factory key (usually lock/unlock/lock sequence). You have to have 2 already programmed keys to successfully use the aftermarket kits. -
Edge sways all over the road above 70 mph.
dabangsta replied to ibChuck's topic in Brakes, Chassis & Suspension
Nexen tires can be okay. Most of their A/S tires are M&S rated, so without knowing what model, hard to make a determination of they factor into it or not. Wider low profile tires are more likely to be affected by tramlining, but there are vehicle dynamics that can affect it as well. I wouldn't suspect the AWD system to play a role in this issue. I suffered from from it a bit on one of my older cars. It stock had 215 wide tires, and I put 265 wide rear, 235 front, with wider rims in the rear, that left the outer edge to edge of the rear tires over 2 inches wider than the front. Not only concrete roads, but just rutted pavement from high ambient temps would cause it also metal grated causeways were interesting. It didn't feel dangerous which is sorta what it feels you are describing, a not locked in vehicle at only 70 seems sketchy. -
Or a completely new type of PTU with the disconnect?
Rubber Splash Shield (maybe???)
dabangsta replied to BMWR1200c's topic in Accessories & Modifications
Mine got ripped off when I hit a semi truck tire that was shredded in the road. It is all a part of the entire "fender splash shield" or "fender liner", not available separate that I could find. It is for noise and to some degree...aerodynamics (forces air under tire). If you look at images/pictures of KT4Z-16103-A https://www.ford.com/product/parts?partNumber=KT4Z16103A§ionId=76647708 it seems to be part of the assembly. -
2008 Edge AWD - loud noise - wheel bearing?
dabangsta replied to ADC's topic in Brakes, Chassis & Suspension
What year and what manufacturer of pads have a squealer? Very few I found for 2016+ (I don't know what years are grouped together) aftermarket have them (Top Notch brand, some Akebono), none on factory installed pads I have seen. None for first gen. -
No really "all weather", which I suspect would be the 3 peak rated snow tires with UTGQ ratings for year around use (CrossClimate2/3 for example). I don't think my tires are worth a separate post. It had Kelly Edge A/S tires on it when I bought it. They had zero miles, the dealership found the cheapest ones they could. They were not great at any one thing, but other than noisy at take off across painted stripes, and would hydroplane in not very deep water, not bad enough for me to replace. Got 53,000 miles on them, still had 4/32 tread left (pretty consistent across entire tread, all 4 tires), decided to get them replaced instead of waiting another 2,000 miles to wear them the rest of the way to the wear bars. Looked for a mid mileage "warranty", high traction and temperature rated (high ambient temps 9 months of the year, 8 hours at 80 mph at 110 degree ambient can end some tires), A/S more summer oriented tire. I don't want 80k tires, but I didn't want 20-30k wear tires, as it gets about 20,000 miles a year, but we get lots of nails and screws in them, something around where it is driven every day for work. Last tire repair they said they likely wouldn't patch it again, ~15-20 patches already. For $750 installed I ended up with Sumitomo HTR A/S P03 from Discount. They are considered UHP A/S, the Tire Rack testing shows them mid pack in most tests, but customer ratings and reviews seem to match my expectations. 1 year road hazard from Sumitomo (I didn't get from TireRack with 2 years road hazard, and I didn't spend $160 on the Discount one, that is one tire). The SUV/Crossover tire segment had some candidates, but usually more costly, and many have temperature rating of B. They are much better than the tires they replace, but how much of that is new versus old. They are much quieter than the ones they replace, even when new. No longer have small steering wheel movement, especially on cement roads. It still "kicks" at each expansion joint, but it doesn't saw back and forth. Got to experience them in standing water, and active rain, and did much better than the previous ones. I didn't hear the wheel wells filling with water and lack of steering. Only weird thing I ran into once was driving at 82 mph, cross gust of ~40-50 mph. Instead of being pushed sideways, it swayed a little bit. Just once, and the entire 4 hour drive was in high winds, and it behaved as expected.
