bhamraS97
Everything posted by bhamraS97
Hi All, I have a rattle in my rear view mirror. The music used to shake the mirror and eventually seems like it developed a rattle. The base where the mirror attaches to the windshield is secure. The mirror itself (where you adjust by hand) rattles. Is there a fix to this? Any suggestions/help is much appreciated Thanks in advance
Hi All, Firstly, I have a 9 speaker ford stock speaker setup. I have been running Rockford 3-way in rears and I am pretty satisfied with sound. The stock would sound distorted at higher volumes, these don't so far Recently, I was listening to music around 22 volume and +5 bass, the stock front speaker sounded fine till 20 but at 22 I could feel the front speaker distort, whereas rear seemed just fine. (Just to add my fader is just +3 from rear) Now, I want to upgrade the front as well but after some research, the best way would be to go with component and I am quite inclined towards these (since I am on a budget). However, I am not willing to change the stock tweeters since from some videos they seem to require modifications but that's for later. Before that, I am wanted to check if the front doors have crossovers installed from factory? And can I just replace front lower mid-range woofer with the above Rockford component woofer and call it a day? Also, what is this device on the front door panels? (I might be sounding stupid here lol) Any suggestions or guidance is welcomed!
I am an idiot! Now I remember changing it when I got the car. Feels like I forgot my car completely 😆 Thank you!
Another question, I just realized the RPM display that shows up on the right side seem to be removed This small image from internet for reference. It still has the proper big RPM display but that small one on the right is missing.
Thanks @omar302@dabangsta Will try your suggestions
Mine is a SEL and has LED Signature lighting (those triangle one on the bumper). In Canada, we do not have configurable DRL option. Currently, my car has low beams as DRL along with the signature LED triangles. I tried enabling the functionality for configurable DRL via settings. However, after changing the mentioned things on forscan, I got the menu and can toggle the menu but the toggling does nothing. The DRL(low beam) would remain off
Hi All, I added the DRL menu to my edge left digital screen. I changed these values below https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true And enabled the menu for IPC(via non-asbuilt menu) using forscan. Now the thing is, the menu is there, I can toggle the menu but it does not turn on the DRL, the DRL stays off. Any idea what I am missing?
Adding DRL control to left instrument cluster - Canadian Edge
bhamraS97 replied to ONEDGE16's topic in 2016 Edge & MKX
Hi @ONEDGE16 I tried the Ford Focus excel sheet to enable DRL option https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true I changed But the DRL option still did not show up. Am I missing something? Please advise Update: Found my mistake (missed to update on value) -
Done Added the signature, right now don't have access to laptop so will double check later but it's a 2018 Ford Edge 3.5L V6
- 90 replies
- dash noise
- dash rattle
(and 4 more)
Hey, as from pictures from @Haz, my 2018 Ford Edge has similar layout as 2.7L model. All I did was, removing the loose middle clips on the side panels on both driver and passenger side and keep the good ones. And for the good ones I added double sided tape inbetween clips and frame to act as cushion and that worked for me. Driven 160 once and no rattle at all. Hope this helps
- 90 replies
- dash noise
- dash rattle
(and 4 more)
Hi All, I want to switch to high beam DRL instead of low beam since I upgraded to LEDs and the high beam is never used in my case so why not use it up for DRL and save the low beams for night drive. I was checking Body Control Module and found DRL related parameters. I just wanted to be sure for what needs to be updated? I have attached two option I feel needs to be changed but any advise is very much appreciated. The two parameters are Allowed DRL Options Using DRL with Turn Signals Thanks!
2018 Ford Edge No Rear Tweeter Wire
bhamraS97 replied to bhamraS97's topic in Audio, Backup, Navigation & SYNC
Hi @Haz, thank you! One clarification, from the wiring diagram, the VME39 circuit is going out from the C702 connector to C730 connector? -
Mine is the SEL Sync 3 with 9 speakers. To overcome the muddy sound on the left side I put it aftermarket speaker (https://www.crutchfield.ca/p_108R6532EM/Infinity-Reference-REF-6532ex.html) and disconnected the right side tweeter for even sound, but oblivious the bass from factory speakers were better so I wanna go back to it but want to fix the tweeter wiring first. -
Hi All, There is no rear tweeter wire on my rear left driver side door. I see wire going through the B pillar but I don't see any pigtail or wire going to the tweeter. The tweeter is there but no wire. If say there is no wire coming for tweeter could I use a T wire connector and use the Circuit VME39 and RME39 to run a wire to tweeter? Please any advise?
Hi All, I have been noticing a delay on driver side high beam. Whenever I toggle the high beam, there is slight delay on driver side. I believe it has been there since the time I swapped to LED, and I don't remember the halogen behavior as it has been a long time but passenger side is instant. I swapped to different LED brands but still the same behavior. Personally, I don't mind that much since I am using low beams for the most part but I would like to get rid of this issue Thanks in advance High_beam_delay.mp4
Hi All, I have been noticing that from last 4 fills I have been using 91 octane but with 91 octane I find that the idle is not so smooth and there is shutter from 1-2 gear more on low speed specially when accelerating on 2nd gear. I thought it might transmission, I re-did the fluid change before 20K kms, the fluid that came out still clean. But even after oil change I felt the shudder. So I went back to using 87 octane, and from last 2 fills, the engine idle again smooth and rarely shutter occur depending on throttle input. I know that 3.5L is a low compression engine but I felt 91 more responsive (probably placebo) Any idea why would that be or anyone experienced shudder?
2018 Ford Edge No Tweeter Wiring Rear Door
Thank you @Haz My bad, I meant to say there is no wiring coming for the Rear Driver Side Tweeter. I checked, all plugs were connected so no unconnected wiring there. Not sure why there is no wiring coming to the tweeter. Apologies for the confusion. -
Hi All, Few days back I opened the rear driver door for dampening and saw that the tweeter wasn't connected. I never sat in the rear seats so never noticed this but found this very disappointing as you can tell that something is not right when you hear song in the back seat. I am not sure how this is even possible but does anyone have any suggestions for this? Thanks!
Thank you @omar302 and @1004ron for all the input. Much appreciated! I did come across someone on youtube comments who removed the fasteners. I tried reaching out for his feedback about how well that worked out but he didn't respond
- 90 replies
- dash noise
- dash rattle
(and 4 more)
@1004ron Thank you for the idea!! Correct me on mine, I was thinking of removing the plastic clips and using the self-tapping screw to tighten them up against the body? I feel that would be a more permanent solution
- 90 replies
- dash noise
- dash rattle
(and 4 more)
@1004ron Thank you for the idea and I did try your fix but eventually, it has returned again. However, it generally happens when driving around 80mph but the thing is if I paid for a costly car I don't expect it to rattle due to such a bad design. What would be your advice if I remove the center plastic clips and let them hang on the 10mm retainers?
- 90 replies
- dash noise
- dash rattle
(and 4 more)
Hi All, Firstly, I am new to these forums so apologize if I made any mistakes posting this. So, talking about the concern I have is. I have a highway rattle that occurs due to splash guard or underbody shields that are on both sides of the driver and passenger. I did fix it temporarily applying the idea from the post as mentioned. https://www.fordedgeforum.com/topic/24176-solved-noise-or-rattle-above-40mph/ However, I am looking for a permanent fix. After some talks and Reddit, people suggested taking those splash guards off but I am not sure if I should do it since it kinda protects the metal frame. But few suggest to take the clips off and leave if rested there by 10mm nuts which I think can work but can anyone suggest if it would be a good idea and if it will not harm anyway in the later run or saying driving at highway speeds. Thanks!
- 90 replies
- dash noise
- dash rattle
(and 4 more)
Hi All, I know I am responding to a quite old thread. But I had a few questions. So as per the post, I applied some similar fixes. But after some talks and especially Reddit, some people suggested to simply just take it off which I am not quite in favor of. The other is people simply removed the clips just resting the guard on the 10mm nuts, which I think might work but then I am concerned if that will have adverse, especially when driving at highway speeds. Can anyone give their opinions? Thanks!
- 90 replies
- dash noise
- dash rattle
(and 4 more)
