MustangMike
About MustangMike
MustangMike's Achievements
  1. I wouldn't buy one. They look like a cheap stick on......wait a minute
  2. That cover looks cheap. BTW, the part that is going to get scratched/marred, is the edge of the bumper right before it slopes 90 degrees. I am just careful about putting things in and out of the cargo area.
  3. Same issues here. Easy/exit feature works when it wants to. On my wifes setting, she unlocks the door with her fob and seat moves into her position and allows easy entry because seat is back, puts key in ignition and seat never moves forward, she has to do it manually, when stopped and removes key, seat moves back for "easy exit". I never had a problem with my setting. Sometimes it works and sometimes it doesn't.... Problem unable to be duplicated at dealer.
  4. It's the fuel injectors doing their job. Ticking sound resonates through the fuel rail. Some are louder than others and I have no idea why. If it gets worse or sporadic, then there is something else wrong.
  5. Throws off the alignment of the steering rack as well as the driveshaft angle. A slight drop of 1" will be ok, but anything lower and you WILL have problems.
  6. I loathe people who do not signal their intentions. If I can get next to them, I will ask them if their turn signal is broken. Many lives can be saved by signaling, and saying I don't use it because it's loud is incompetent and just plain reckless.
  7. Thanks Izzy, I have the stick on weights on the inside of the rims on my "Stang. I think it is horrible to put the wheel weights on the outside of the rim....I wasn't sure if they could use the weights on the inside of the rim. If so, this is what I will have done.
  8. The issue is not with the "chrome Cladding" rather with the outside exposed metal rim which the wheel weights are attached to. I have peeling/flaking issues on all rims. The plastic is good. Was the issue of the outer lip of the rim addressed by the new manufacturer Lacks? I am about to take the car in for this issue, and do not want any crap from the service manager about replacement.
  9. Mine does the exact same thing. Creaking/ clicking sound which is very loud......only did it in the summer on hot days.
  10. What exactly was I "wrong" about ? I f you can afford a lambo, why not just buy a porsche cayenne Turbo S ? Besides.....street racing is illegal.... :burnout: The spent exhaust gasses spin the turbine, not the compressor. There is no "compressor" this is forced induction douche. The helical gears compress the air, feeding the motor. Douche.
  11. They need to replace the camshaft position sensor and possibly the exhaust control valve solenoid.. I had the same issues, running rough and jerky idle with foot on brake. Is your car color blazing copper by any chance ? They have 3 now at my local dealership with same issues......all blazing copper :o Someone else on hhere has same issues.....also coppper !
