Michelle92648
Everything posted by Michelle92648
  1. Thanks so much for taking the time to reply - advice sounds good !
  2. When I go to press the remote to lock. Randomly it does a few rapid noises apposed to just one to confirm it’s locked ? I replaced the battery as my first trouble shoot ? what does the several horn noises mean, instead of just one ?
  3. Hello, newbie here. Since I purchased a used 2011 Ford Edge SEL the tire pressure sensor fault has been on. The pressure is perfect on all 4 tires, with good tread. This random noise, which sounds like a metal wringer inside the tire ? It does not make the noise on freeway, and some days for like 3 minutes, then nothing, after researching - seems like the sensor broke off inside the front tire. Should I buy a new tire ? Will the broken sensor damage the tire inside causing a blow out or flat ? and can I drive it and just ingnore the warning light? I took it to my local Ford dealer before I figured out the cause, they said bad engine mounts, and wanted like $1600 when the car was only $9K and the wrong diagnosis. RIP off alert !! It won’t make the noise if you test drove it, anyways. So random when it does, usually when you first drive it after being parked. Any advice ?
