Dulce
About Dulce
Dulce's Achievements
  1. I own a 2016 Ford edge SE with 200k + and i used K-seal in two separate occasions (few months apart) and it has resolved the issue for me. best of luck
  2. I have ?… and it works fine. I have no plans in replacing my engine, just driving it till it drops. I have used the Kseal in coolant and has helped alot. I know its just a bandaid but I will continue to bandaid to keep it running. Note : 2016 Ford Edge current mileage 113k
  3. Happy New Year Everyone ?, Mid November I added K-Seal to my coolant reservoir. About a week after I poured the K -seal, the water noise pretty much resolved, my heater started working again and the engine light went off (disappeared/ not on anymore). I still have coolant loss about the same amount. I had one incident were car did not want to turn on at all.Turned ac/heater off and yup car turned on (no problem since then even with heater/ac on). Had two incidents were thermostat suddenly jump to overheat car alarm when off. Pulled over, turned off car no smoke or sign of it over heating coolant level was good. Turned car back on almost immediately and back to normal like nothing , drove it home 200+miles. Still has a slight rough start at times, still fill up coolant every so often depending how far I drive. It seems it only resolved the water noise and engine light turned off. Does it work ???…… I don’t really know lol !!
  4. 2016 Ford edge 2.0 108k+ mileage falls under the (TSB 19-2346) and needs new engine block. - currently my car has shown no signs of over heating - does have rough start - some coolant loss but not alot at once - water noise I have decided to just keep driving it and just check coolant levels to make sure it doesn’t overheat? I will keep you guys posted see how long it last, wish me luck ??
  5. Yup, exactly!!! Since I was responding to the question asking “ Has anyone had assistance from Ford when this failure occurred “outside the warranty mileage and period?“ ??….. In other words since my car is out of warranty Ford is not taking responsibility for it and I wouldn’t bother asking or expect any assistance from Ford. Hope thats a little more clear on what I ment.
  6. I’m not even bothering, from the sound of it Ford is not taking responsibility for problem. I wish everyone the best on this issue, really sad. But for a huge company like Ford, I’m sure they don’t care about the little guy. So this issue is not a priority to them meaning the loss is minimal to them. So sad ?
  7. I asked the same question and was told that the cost for part + labor work to just change the gasket was high and wouldn’t guarantee a fix and will end up with double cost.??‍♀️
  8. I’m sorry you are also having the issue. But I have seen it on videos but I have not tried it.
  9. Sorry, but do you mean that because it’s only recommending something it doesn’t mean it needs it? Sorry just trying to understand.
  10. I have always used regular gas (87). I don’t have visible coolant leak, but if coolant (water) in cylinders and loss of coolant is considered a form of leak, then yes there is a leak.
  11. So now that I’m little more calm and not running like “a chicken without a head” I was reading everything carefully and a little confused in regards to the term “ long block engine” v “engine”. So do I not need a whole new engine or only the long block engine or are they the same thing? Sorry, just confused on whats what and what will definitely fix the issue?
  12. I will take all the help I can get. I still owe $14k on my car loan so seen it’s going to cost me about $8k or more (I’m just guessing I don’t really know the price) really hurts. At this point I guess taking out a loan to get new engine ?. Thank you all for your kindness and time to share your thoughts. This is awesome ?
  13. I just opened the link… going to read it. I’m so stressed. I can’t believe just 5 yrs old and it needs new engine. I kept it well maintained and just put over $400 on maintenance
  14. So I was just advised I need a whole new engine. They said water in cylinders due to possible gasket broken/cracked and it’s recommended to get a whole new engine due to cost of just replacing the gasket and having issues later requiring new engine. ?
