I'll add another data point -
I have a 2015 2.0L Edge (~95k miles) that was experiencing a small evap leak (P0456) and unable to bleed up fuel tank vacuum (P1450). It was also struggling to crank after getting gas, so I narrowed it down to the purge valve needed to be replaced.
Based on this thread, I decided to purchase only the valve from Amazon.
https://www.amazon.com/gp/product/B0855STNVD/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
I used a heat gun to remove the broken valve, but I ended up damaging the hard tubing in the process. I ended up removing the ~6" piece of hard tubing and replaced it with some 3/8" I/D rubber hose from autozone with some hose clamps.
https://www.autozone.com/plumbing-hosing/rubber-hose/p/continental-24in-x-3-8in-fuel-emissions-hose/534817_0_0
Not the most ideal fix, but Ford doesn't put you in the best spot when it comes to parts. So far, everything is working fine and the codes are staying clear. I'll update here if I end up having any issues with the valve or hose!
I appreciate the help from those above!
