Correy
About Correy
1,067 profile views
Correy's Achievements
  1. I'm missing a small trim piece that covers a screw in the liftgate area (please see photo). Anyone know where I can get one or a Ford part number? Thanks!
  2. This issue turned out to be a bad battery......not sending 12v to the BCM. After I posted this, similar codes popped up and the Intelligent Access would only function on the driver's door. New battery installed and now no codes ?
  3. You're not kidding. I ended up removing the headlight assembly.
  4. Is there a trick to getting the plug to fit over the blade connectors?
  5. Very helpful!! THANK YOU!! ?
  6. Doing a DTC scan and found this. Anyone know what it means and is it something I should bring in (I have 3 months remaining on my factory warranty)
  7. Hi, Just curious. Do you have a link to the bulb you're using and did you get any "light out" errors? PS Looks awesome!!
  8. I want to replace the DRL halogen bulb with LED. On HID models the DRL is located where the high beam bulb would be in non--HID models since HID bulbs are dual beam thus no need for a separate high beam.
  9. Just goes to show you.....newer isn't always better
  10. Wouldn't it make more sense to just design a more robust clip
  11. I was replacing my cabin air filter and discovered the screws on the filter door panel were missing. I wanted to replace them since tabs on the door is also broken. Does anyone know what the part number is or a generic equivalent? Thanks!!
  12. I have a 2018 Sport with the HID headlights. Where the high beam would be in a non-HID vehicle there is an H15 halogen bulb. I'd like to replace it with an LED. If anyone knows a suitable bulb please let know. Thanks ?
