Nsohail76
About Nsohail76
Nsohail76's Achievements
  1. Thanks. I fixed it today. There was a coolant hose right above the turbo that i forgot to put the clamp back on. Which i for some reason removed (not needed) Turbo approx around 18 lbs
  2. Can someone provide which hose on the back of the turbo fits into which one. I forgot to mark them and now i have a coolant leak. Not able to figure out which one is the coolant hose. Any advise is appreciated
  3. You can remove your turbo without removing the engine!!!Loosen up the CAT and you will have enough room
  4. I ended up changing it myself, turbo is working now but i have a coolant leak from one of the hoses. Not able to figure out which one it is. The 2 hoses on the back. I am not sure which one is coolant hose. Let me know if you know anything. If you have a picture of your turbo from the side. That will help too
  5. Did everything work out well for you with replacing by yourself? I am planning on doing it on my wife’s edge tomorrow. Please let me know if you have any tips or lessons learnt.
