Everything posted by Victor
Interesting. I'll connect my OBD2 Scanner and see what I get. I'll keep you posted.
Fascinating! What would happen if you delete all the DTC's with an OBD2 scanner?
I'm having the same problem as well. Everything was fine up until a couple of days ago. On the way home from work I noticed that the battery symbol popped up on my dashboard. I found it odd but didn't really think that much of it. When I got home, I put the car in park and took the keys out of the ignition. I noticed I still had room in front me and so I decided to pull forward just a bit more. When I went to start my car it wouldn't turnover. It had enough power to run all of the accessories but not enough to start the car. I figured I needed a new battery so I bought a new one but on the way to work the battery symbol popped up on my dashboard again.
Can someone please help me? A couple of days ago I decided to open the sun roof all the way on my 2009 FORD EDGE LIMITED and it got stuck.
Ok, I recently replaced the spark plugs and pcv valve. Besides that, looks like I have a lot of work ahead. Thanks for your input.
I’ve kept the oil changes up to date. Changing it every 6 months. I recently replaced the spark plugs as well. Oh and I did flush the coolant system a couple years back.
So my 2009 Edge Limited just reached 130,000 miles. Any recommendations maintenance wise?
Does anybody know where I can buy the chrome cadding for the 20" rim?
I use Mobile 1 10w-30 on mine.
If not, can I use a random bolt or would that cause the manifold not to seal properly?
Here's a link.
My 2009 Edge Limited has the same problem. Also, it's always recommended to change both front and rear brakes. Same for the rotors. As for the rotors it depends how worn the are.
Seems simple. Here's a link.
Where can I buy replacement bolts for this? I kind of snapped 2 of them when I was putting it back on.
@enigma-2 I'm about to reach 124,000 miles. But as I previously stated, the last time I changed my oil was last year in July. So it's about time I change it again. Regarding the coolant, I've only changed it one time and that was in 2020 if im not mistaken. Bro, did you really say I should consider changing the blinker fluid? Lmfao I have H11 LED headlights so I don't need Blinker Fluid.
Thank you for all of your inputs guys. I appreciate it.
I live in LA, and since my Edge has over 120,000 miles on it, I've been using 10w30 Full Synthetic.
I change the oil and filter every 6 months or so. As for the filter, I use the Motorcraft FL-500 I haven't changed it since last year in July so it's about time I get to it. I don't know if the previous owner had the water pump worked on or not.
Quick question, which oil would you guys recommend for a 2009 Ford Edge Limited with 123,000+ miles? Lately, I have been using Mobile 1 High Mileage Full Synthetic. Any thoughts?
Does anyone know how much gap there should be between the fender and the front left door? I recently installed a new door on my 2009 Edge Limited but don't know how much gap there has to be all around the door.
Power Locks not completely working
Victor replied to LM1989's topic in Alarms, Keyless Entry, Locks & Remote Start
You might have to replace the door lock/unlock button its self. -
2009 Ford Edge Limited Front Door Hinge Torque Specs
Victor replied to Victor's topic in Interior, A.C., Heat, Interior Trim
Awesome. Thank you.
