willzzzzzzzz
Everything posted by willzzzzzzzz
  1. Hello Everyone, I have a 2013 Edge. About two years ago, I had my driver side rear door ajar light come on. It seemed to go off if I slammed the door. I looked at forums and grounded the solid green wire in that door and the issue went away. Recently the same door ajar indicator came on again. If I slammed the door or was driving down the road the indicator would toggle on and off. I popped the door panel back off and checked the wire and I had a good ground still. My thought was that the wire or connection is bad further up near the brains of the car. I traced the green wire from the back door panel, thru the driver side door plate, thru the firewall, under the BCM and all the way to the PCM/ECM. I tested continuity between the wire in the rear of the door and the PCM/ECM connector and I had a connection via my multimeter. My thought now is that the PCM/ECM may be bad??? At the end of the day, I just want indicator ignored and my battery to last. I can check the door when using it. Any thoughts on this as a next step?
