edgeidiot
About edgeidiot
edgeidiot's Achievements
  1. Concerning the original TPMS warning, did you determine why one tire suddenly lost ten psi? I am trying to understand what could cause this. As little as a tiny leak in the tire or the wheel should have caused the tire to completely deflate in a week. If the valve stem was leaking, the TPMS occasionally should have measured that the pressure was low. Was it parked in an airport parking lot where someone depressed the value stem? What was the pressure for the other three?
  2. I just found out that there is an updated version using Magsafe: 2019, 2020, 2021, 2022, 2023, 2024 Ford Edge Phone wireless charging phone mount | eBay
  3. I found this mount on ebay. It was made for and fits in the cubby hole. 2019, 2020, 2021, 2022, 2023, 2024 Ford Edge Phone mount black | eBay
  4. I noticed that you have Kelly Edge tires. Was it a coincidence?
  5. There is a difference in the circumference (height) of these sizes. Aspect ratio is the percentage of the sidewall versus the tire width. Rim diameter only means that a tire will fit the rim. In the specific case above, the 275's are 8 mm taller, 10 mm wider and will revolve 7 times less per mile which will cause a slight speedometer error.
  6. I found the replacement part numbers: Left KT4Z-16103-A Right KT4Z-16102-A Around $70 each side at your favorite online Ford parts dealer.
  7. This happens on my 2020 Edge once in a awhile. When your battery reaches a status of low charge, you should see a message on your SYNC3 screen. Normally, the accessories (like the SYNC3 system) remain on until you open a door. In the low charge mode, the accessories turn off when the engine is turned off. Are you experiencing the Stop/Start function is also not working? To reset, all you need to do is to recharge your battery.
  8. I have added the hood insulation pad. It is a direct fit for my 2020. Their website shows that it fits all 2020 models (I do not know about the other years, but unless they also deleted the grommet holes, I would think it fits any model of this generation.) The part number is KT42Z16738B. The grommets are included. Should be $100. I should have added that the installation takes no time.
  9. Been looking for a cell phone mount and came across this. What do you think? 2019, 2020, 2021, 2022, 2023, 2024 Ford Edge Phone mount black | eBay
  10. Groovy! Remember the Goodyear Polyglas GT? I love a challenge. Firestone makes a P245/60R18 All Terrain tire with OWL (outline white letters). I will take my tie-dye shirt with me on my way to the social security office.
  11. Are you trying to find a used set of wheels? Gosh, I would think that it would be like finding a needle in a haystack. I don't think Ford sold that many Edge's with this package. Suggest contacting a junkyard to see if they would do country-wide search for the wheels you want. They will need the year and model trim for the vehicle. fordauthority.com has a page that shows by year what wheels were available. If that fails, you may have to order from the dealer (search for the Ford dealers listed in this forum that sell parts at prices lower than other dealers.) I did find a site that says they sell only OEM rims: Premium Factory OEM Wheels | Detroit Wheel and Tire. Hard to match the wheel above versus the pictures on their site. By my untrained eye, the closest one runs $2,700 for a set of four and I am not sure if that includes shipping. See if they will give you a discount for exchanging your old rims. I wish you the best of luck.
  12. You should be able to use the search box to find previous posts about installing a Dash Cam. I don't remember that anyone mentioned piercing the firewall. There is a fuse box in the cabin.
  13. Yes, I am the old tire salesman. The closest match to the diameter of the 265/40R21 currently on your vehicle in an 18-inch rim is a 245/60R18 which is coincidentally the stock tire on other Edge trims. You did not say whether you are going to buy OEM or aftermarket rims. OEM Rims should cost around $200 and up at online Ford dealers (ymmv). I have attached the nerd specs. Doc133.pdf
  14. Yes, I can see that they fit. What I notice is that your new tire (315/35R20) is two inches less in diameter than the old tire (255/50R19.) It may cause increased wear because of the reduced diameter and a greater speedometer error.
