MSCOSC
Everything posted by MSCOSC
Various Used but Good Stock Parts for late 2015 thru 2019 Edge Sport
MSCOSC replied to snmjim's topic in Classifieds
How much you want for the black exhaust bezels? Any photos? -
I was trying to do some data logging and it's hard to tell. I can see that the intake box temperature generally cools down faster with the Xtra intake but is hard to see if that translates into more power.
That's the point. Instead of the air being recirculating back through the intake(no sound) it comes straight out the pipe into the atmosphere. Other blow off valve adapters accomplish this same thing by stacking up the valve. To my understanding, this accomplishes the same exact thing. The valve stays closed all the time unless you're in boost and let off the gas pedal. Even though you see that 1" port wide open on the blow off valve side, the valve is closed within.
I am also curious about a forscan mod that can enable this
You should make the auxiliary air port mate to the back of the v2 lid some how. Or even forgo the factory snorkel and make the aux line larger and feed into where the factory snorkel goes.
I'm OK with some trial and error if you are lol One way you can try to test is to slide your battery forward to the last available hold down point.
You don't want the snorkel to attach to the top of the box, it feeds from the bottom in case water/ moisture gets in there
I saw that photo I guess I just didn't realize the context. Have you considered making the lower box include the snorkel? or at least the part that feeds through that air inlet, I wonder if it could be integrated into one piece
Damn guy that looks incredible. I'm interested to see how you mate the snorkel to the box. Doesn't the OEM one snap into place?
Got mine today. Install was a breeze, thanks for all your hard work!
Extremely impressed by the progress!
The AFE should fit but it will not seal against the top of the hood like it will on the ST models
Is the new box much wider than the factory one? I have a 94r battery in there which is the largest you can fit in the tray, there is a hole for the bracket and everything.
I feel like you'll sell them without much trouble
I have not received my intake yet so I will do some basic data logging to see what I can find. Any other PIDs worth tracking?
Pretty cool to see the process!
I am really eager to give you my money
