bscott94
Everything posted by bscott94
Group 65 Battery in 2nd Gen Possible?
bscott94 replied to omar302's topic in 2015+ Edge & MKX Generation II
I'm glad this thread exists. We replaced our battery with an Interstate from Costco shortly after we bought our 2017 Sport (June 2021). I had a hard time believing that we needed a new one already but I bought the Topdon tester that's linked in this thread and tested it. Turns out it is bad so I'll be heading to Costco this evening to snag an Interstate H7. My symptoms were the Battery Saver screen popping up after just sitting on ACC for less than 5 minutes and lately, my wife has gotten in to leave for work after the car sat for 2 days and we've had to jump it. -
17 Sport - Bilstein B6 Struts with H&R Springs
bscott94 replied to bscott94's topic in Brakes, Chassis & Suspension
Bringing this thread back up. I love the lowered look but the ride is kind of annoying. I know it will be different than stock but I have a noise that, if resolved, I can live with everything else. Whenever I'm on a rough road or go over speed bumps, there is a clunk in the rear end. It sounds like when my old car had broken sway bar end links in the front end but this noise is in the back. I replaced the rear sway bar end links when I installed the springs and new shocks. I've jacked it up and checked bolts and looked for marks that show something is hitting something and I haven't found anything. Has anyone else had this? How do I fix it? -
Well it finally happened. I got home Friday and the cover was missing. I think it was blown off in the touchless carwash. It only took like 15 trips through it. I ordered a used one on Ebay but it's white so I'm going to try to wrap it in in black carbon fiber vinyl. We'll see how that looks. @omar302, do you have the file for this in the instructions? 1. Lower the headliner. Refer to: Headliner Lowering (50105 Interior Trim and Ornamentation, Removal and Installation).
I would try a wash and hand polish. I use mostly Adam's Polishes and have used this product before so that's my suggestion. Any light polish should work though. https://adamspolishes.com/products/adam-s-revive-fine-hand-car-polish?_pos=1&_sid=25c2bdc8d&_ss=r
I've searched on here and on Google and can't really find what I'm looking for. I'm trying to hard wire a dashcam that came with fuse taps. It has one tap for an ignition source for regular duty and then one for constant for parking mode. I see a lot of unused fuses in this breakdown. Is there somewhere that will tell me which of these are ignition and which are constant? I assume these spares are hot? If not, what should I use that is hot.
Does this say there is a new oil pan? With a built in gasket? I was just going to deal with the leaking pan since it's been replaced at least twice but if there's a better replacement now, I might have to call. I see the Warranty Status section but I don't understand it. Do you know if this covers anything with the issue? I just hit 69k miles on a 2017
I wouldn't try. I got a spring compressor kit from Harbor Freight for $35 and it worked perfectly. -
bscott94 replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
I love it. Except I hit my head on the hatch now even with the top point saved. I live in Indianapolis so not many twisty roads but I'm 30 seconds from Carmel, the city of roundabouts so I get my need for twisties from those. It is much more flat ripping through roundies! -
Moving to the rear. I found the following on rear subframe replacement as I've read dropping the subframe makes rear spring replacement easier. I don't need to completely remove the subframe so the workshop manual section has a lot of extra steps. Do I just need to remove the shocks, put a jack under the diff and mark and remove the 4 bolts from the first part of the workshop manual, and lower it slightly to pull out the springs? -
Thank you! That is very helpful. I ordered everything suggested/available from Tire Rack/RockAuto hoping I could assembly the new struts before I take everything apart but it looks like I'll reuse some rubber seats and other small items from the stock set up. -
@Haz, can you share the strut info from the workshop manual? Would that be different than the Haynes manual? I know it won't be the exact same as the Bilstein strut by hopefully it's the same components. -
Does anyone have a video or pictures that show how to assemble B6 struts with H&R springs? I think I ordered everything I needed but I can't make things fit together how I would expect them to. I found the link below but it's H&R Springs on stock struts. I can't find anything that lists the other parts that are needed to complete a strut. I have the Haynes Manual and it shows stock struts but it still seems like something is missing. Below is what I have. https://drive.google.com/file/d/1wQ3WRD6zvzHaAbxE3hCZpyKIwbBI3-Gs/view
Mine hasn't broken off completely but I think the only screws that haven't broken are along the back. I don't want to do all of the work to remove the unit so I might just break it off the rest of the way and carefully epoxy it back on. I have looked around on here to see this situation and never found it. I wish I could just buy the cover but I don't think it's sold separately.
2019 AWD Titanium 13mph 'thud'
bscott94 replied to Magnetic19's topic in 2019-Current Edge & Nautilius
I have a 2017 Sport and I felt/heard bad thumping when going through roundabouts. I think it was during the 2-3 shift. I'm not sure if It was because I kinda "launch" into the RAB in second, coast to the middle of the RAB, then accelerate out. I think the 2-3 shift was happening during my coast and then the acceleration was slamming it into gear or something. I reset the TCM in ForScan and it seems to be less aggressive. I don't know if it actually did anything or not but it seems like the reset helped at least a little bit. -
Engine wants to stall - Code P1450 & P144A/C - Evap Purge Valve
bscott94 replied to shumax's topic in 2017-2018 Edge & MKX
The PDF from the comment below has a good diagram showing the part. I ordered my part off of Rock Auto. I picked my car and it showed me the correct parts. I think it was around $50 -
Thanks. Is there anything that says whether or not the plastic fin shaped cover can be removed from the base? I know there are things between the fin and the base so there has to be a way to get in there. I don't know if they're screwed/clipped together or if they're glued together after the internals are installed.
Does anyone have any experience with this? It looks like the cover might screw onto the base so I might have some broken plastic where it screws together but I can't find any info
I wish this info would've been available a few months ago. I got the aftermarket ones and removed the covers to replace the blue covers on the plastic that fits. It worked fine but just buying and popping in would've been preferred. -
? I said the same thing to my fiance. I was going to buy it back, tune it and make it lower and wider. I think it would make it fun on a road course lol. If we had space to store a non street car, it would be highly considered. We also thought about buying it back, putting a bumper cover on it, and calling it "Rebuilt". It's on it's way to a new shop for a second opinion. We might just get it back repaired with a clean title. -
It might not be totaled after all. Our insurance sent someone to look at it and the damage to the left frame rail is so minor, he believes it can be pulled back into shape. He said he's seen it done before. He couldn't see any damage to the right frame rail but the shop claims there is. I think we are going to take it to a new shop to get a second opinion. Hopefully we don't have to wait another month for the next shop. Fingers crossed we get our ride back soon. It looks like most of the damage to the frame rail is just on the bumper reinforcement mounting surface which, based on the spot welds, is a part that can be removed and replaced. -
Found out our Edge is going to get totaled out yesterday. My fiance was rear-ended in stop and go traffic at a roundabout. It was super low speed but the body shop found the rear frame rails were bent so the quote went from $1500 to $33,000. I hope we can find another low mileage Sport to replace this one as we loved it. We are just waiting on insurance to review the new quote and give us our payout amount. Then we need to figure out how to pay off our current loan, get a new loan, find a new car, etc. Ugh. I thought we were done with this for a while. -
I was washing my car a few weeks ago and noticed the cover on the antenna is loose at the front of the fin. I've searched on here and only found antennas broken off completely. Does the cover pop on and off? Can I take it off and stick it back on with double sided tape or do I need to replace the whole unit for the cover to be mounted securely?
Definitely ask. There's no harm in that. But don't be surprised if they say it's not covered. It's fairly cheap and easy to fix so I wasn't super upset that they told me no.
- 4 replies
- warranty
- purge valve
