ymerameha
About ymerameha
ymerameha's Achievements
Hello forum! I'm having a bit of trouble interpreting the wiring diagrams. Which heated oxygen sensor wire on the diagram is the signal wire? VS+? Is there somewhere the meanings of these abbreviations? What do the rest of the wire abbreviations for this sensor mean? Many thanks in advance to those who answered. Since I don't know much English myself, it's quite difficult to figure out what these abbreviations mean.
Hello The engine is Duratorq 2.0L. ForScan displays two PIDs per DPF. DPF_LOAD and DPF_SOOT_LD. The Internet says about them that DPF_LOAD is based on the actual measured differential pressure and DPF_SOOT is calculated using a preset algorithm. I think these numbers could be similar or at least the same size. My own is that DPF_LOAD is 12% - ~ 110% and DPF_SOOT_LD is 1% - 8%. I drove a "test car" and it has both readings similar. Can anyone comment on what could be the difference in the readings? Could someone look at your car numbers and confirm that this is the case? DPF gets full very soon as a result.
Hello I get occasionally DTC error B14DA - Right Headlamp Light Distribution Actuator, Performance Or Incorrect Operation. I removed the headlight to look maybe I can see something, but there aren't very many openings or anything to look at behind. Only one relatively small hole behind electronic module (HCM?) What if bulb needs replacement? Do they need any replacement? I'm looking at the label - Full LED ADB. Are they really full LEDs? I was always thinking they are xenons. Can I open the light case? Is there any way to repair it or replace it with something else? The new part costs 1750 EUR.
So. Injectors replaced with new ones and coded. Engine still smokes. English is not my first language. Even not second. @1004ron do you mean lead-down = leak-down test? It's 110 000 km I'm not the firs owner. I bought it with 90,000 miles. According to the documents, all the prescribed services have been performed more or less according to the mileage. I have changed the engine oil twice (10,000 km).
Thanks for explaining. I just noticed that my post was made in the wrong forum. My Edge engine is a Duratorq-TDCi, not an EcoBoost. This can be a little confusing here. Maybe we're talking about different engines. What engines are you talking about @Lostlittlelamb, @Nsohail76? I don't know which forum my post would actually fit into.
@Lostlittlelamb Did you get out your turbo?
If the injectors have been replaced, I think against the used ones, but they are not coded, can it smoke so much?
No. Absolutely not. Could this be the reason why DPF is regenerated every 10-15 km?
Hi everybody. What do you think, is this normal? https://youtu.be/itXdPIPxlFk
@Lostlittlelamb I don't know. I've not changed my turbo yet. Maybe @Nsohail76 can help?
I ordered a job from a wheels restoration company. They are cleaned, primed, powder coated and varnished. In the original there was only varnish and therefore in our conditions they corroded.
My car is still in dealer and I don't have any pictures of turbo. My turbo is like https://spolshy.com.ua/product/9805482485/ or https://atomcarparts.co.uk/product/turbocharger-no-10009700232-for-ford-mondeo-s-max-galxy-2-0-tdci/ Page from service manual where stated to be prepared to collect escaping fluid: Maybe that helps you and thank you for info. How much do you think the turbo weighs?
@Nsohail76 did you get your wife's Edge turbo replaced?
I haven't replaced it yet. The car is already a couple of weeks at the dealer at defection. To get another opinion. They are not currently saying that the turbol is faulty. The only thing they have said is that the correct temperatures are not achieved during regeneration of DPF. They ordered a new fuel vapour and it will be replaced when arriving. Then we will see if my saga continues. Looks like you can give me some advice instead. My most burning question is whether the turbo can be reached without removing the engine?
