Todd2299
Everything posted by Todd2299
LIncoln MKX to Ford Edge Instrument Cluster Swap
Todd2299 replied to onyxbfly's topic in Accessories & Modifications
Try searching for Robert Ingle (through FaceBook). He did mine a couple years ago. He's in the US, and for the cluster (salvage w/.5 miles on the odometer) the mask, programmed the firmware and even did the Ford Edge Logo and Ford Performance logo. "Only" set me back a little over $700 back then. It was almost completely turn key. All I had to do was use FORScan to update the odometer to match the original cluster. VERY easy.- 110 replies
- digital instrument cluster swap
- digital dash swap
- (and 3 more)
I purchased it from Amazon for about $45. Aeroskin flush mount by Auto Ventshade (AVS) It's a perfect fit. Here is the link: https://www.amazon.com/Auto-Ventshade-322115-Protector-2015-2018/dp/B00W1MA5PA/ref=sr_1_1?dchild=1&keywords=Auto+Ventshade+322115+Aeroskin+Flush+Mount+Dark+Smoke+Hood+Protector+for+2015-2018+Ford+Edge&qid=1619560907&sr=8-1
onyxbfly is correct. Mine would have been $650, but I wanted the EDGE and Ford Performance graphics installed as well. Unfortunately the Edge firmware would not accept the graphics pack. The person that did this for me had to go through a third party since he does these for the Ford Fusions, but has never worked on the Edge before now. Now that he has the modified firmware, he can do more of them if anyone is interested. He also has a few of the masks for the Edge which can be the biggest challenge to source. His IPCs are truly plug and play with no programming needed on your side. His name is Robert Ingle and can be found on FaceBook.
It was one of the first changes I made. Just cleaned them up, masked off around them and sprayed 4 coats of gloss black spray paint. Thanks for asking! I like to make subtle changes, like removing the factory badges and then using the black and red EcoBoost badges. One on the rear and one on the lower front corner of each front door. If you look at the rear side pic, you may notice the blacked out centers of the door handles. Used gloss black vinyl tape to cover them since other car doors kept hitting and chipping the white paint. Problem solved. Another touch was covering the Ford emblems and also using red gloss vinyl tape on the front grill inserts.
Can Instrument Cluster Screens Be Updated?
Todd2299 replied to kevin_ramoutar's topic in Accessories & Modifications
Hello all. I am kind of new here, but wanted to share this with anyone who may be interested. I reached out to Robert Ingle (through FaceBook) as he has done these MKX swaps for many many Fusions. I was so impressed with his work, that I reached out to him to help me with one for my 2016 Edge Sport. Here is what I received. The cluster was out of a 2016 MKX that only had .5 miles on the odometer as it was totaled by hail damage before it ever left the dealership. He was able to source the mask and cluster as well as "reverse engineer" the firmware and graphics pack to work with my car. All I did was send him my VIN and the current mileage, he did the rest. Literally plug and play, EVERYTHING (adaptive cruise, lane keep, etc) worked as it should and I could not be happier. I'll admit that I dropped about $700 all in, but he was even able to get the Ford Performance and Edge graphics installed. Some of my costs were for the software engineering, but now that he has that part figured out, they may not cost quite as much. He mentioned having a few masks for our cars left if anyone is interested in a true "turn-key" solution to adding an awesome IPC upgrade If interested, you should search to him on Facebook under his name. -
Hello all. I am kind of new here, but wanted to share this with anyone who may be interested. I reached out to Robert Ingle (through FaceBook) as he has done these MKX swaps for many many Fusions. I was so impressed with his work, that I reached out to him to help me with one for my 2016 Edge Sport. Here is what I received. The cluster was out of a 2016 MKX that only had .5 miles on the odometer as it was totaled by hail damage before it ever left the dealership. He was able to source the mask and cluster as well as "reverse engineer" the firmware to work with my car. All I did was send him my VIN and the current mileage, he did the rest. Literally plug and play, EVERYTHING (adaptive cruise, lane keep, etc) worked as it should and I could not be happier. He mentioned having a few masks for our cars left if anyone is interested in a true "turn-key" solution to adding an awesome IPC upgrade If interested, you should search for him on Facebook under his name.- 110 replies
- 4
- digital dash swap
- (and 3 more)
Is the Livernois tuner still available and if so, has the unit been "unmarried" from your Edge? I only see one current model for sale from Livernois, the "Mycalibrator" tuner. Thanks for your time and help.
