Todd2299
About Todd2299
Todd2299's Achievements
  1. Try searching for Robert Ingle (through FaceBook). He did mine a couple years ago. He's in the US, and for the cluster (salvage w/.5 miles on the odometer) the mask, programmed the firmware and even did the Ford Edge Logo and Ford Performance logo. "Only" set me back a little over $700 back then. It was almost completely turn key. All I had to do was use FORScan to update the odometer to match the original cluster. VERY easy.
  2. Thank you very much!
  3. Todd2299
    I'll try to put something together soon
  4. I purchased it from Amazon for about $45. Aeroskin flush mount by Auto Ventshade (AVS) It's a perfect fit. Here is the link: https://www.amazon.com/Auto-Ventshade-322115-Protector-2015-2018/dp/B00W1MA5PA/ref=sr_1_1?dchild=1&keywords=Auto+Ventshade+322115+Aeroskin+Flush+Mount+Dark+Smoke+Hood+Protector+for+2015-2018+Ford+Edge&qid=1619560907&sr=8-1
  5. Thanks, much appreciated!
  6. Todd2299
    Thank you! Gloss red pinstripe tape on Amazon (of course) it was .236" wide and was a perfect fit. Less than $10 for a 33' roll
  7. Todd2299
    onyxbfly is correct. Mine would have been $650, but I wanted the EDGE and Ford Performance graphics installed as well. Unfortunately the Edge firmware would not accept the graphics pack. The person that did this for me had to go through a third party since he does these for the Ford Fusions, but has never worked on the Edge before now. Now that he has the modified firmware, he can do more of them if anyone is interested. He also has a few of the masks for the Edge which can be the biggest challenge to source. His IPCs are truly plug and play with no programming needed on your side. His name is Robert Ingle and can be found on FaceBook.
  8. Todd2299
    MKX IPC swap with Ford Performance and Edge graphics installed. Other than running the LMS E30 tune, its my favorite change so far.
  9. Only changes visible in this pic were adding the black/red EcoBoost badges on the front doors and using gloss black vinyl wrap tape over the door handle centers. Kept getting paint chips from being hit by other car doors in parking lots and was tired of touching them up. Problem solved.
  10. Somewhat subtle styling by installing simple gloss red vinyl tape inside the front grill recesses. Also used light (70%) tinting over the turn signals and side markers leaving the low beam projector and high beam areas clear.
  11. Todd2299
    It was one of the first changes I made. Just cleaned them up, masked off around them and sprayed 4 coats of gloss black spray paint. Thanks for asking! I like to make subtle changes, like removing the factory badges and then using the black and red EcoBoost badges. One on the rear and one on the lower front corner of each front door. If you look at the rear side pic, you may notice the blacked out centers of the door handles. Used gloss black vinyl tape to cover them since other car doors kept hitting and chipping the white paint. Problem solved. Another touch was covering the Ford emblems and also using red gloss vinyl tape on the front grill inserts.
