niceonept
    8
About niceonept
7,391 profile views
niceonept's Achievements
  1. CalMac Ferry by the look of it. Do you live up there...or visiting?
  2. It looks good, but "American made"? The Ford Edge was made in Oakville, Canada.
  3. niceonept
    You can see the right rear seat belt in that pic?
  4. I don't know what MP3 player you are using but I have six Apple iPod Nanos and an iPod touch in my car and all play albums and playlists in the correct order. Sync also allows you to over-ride it and shuffle them, if that's what you want. Maybe the problem is the version of Sync you have? I have Sync 3 in my 2018 Edge which works ok with iPod Nanos and Touches but not with the iPod Classic, which worked fine with Sync 2 in my Ford Mondeo, so maybe Fords are abandoning support altogether?
  5. Buy yourself a cheap iPod Nano and load your mp3 files onto that, giving the tracks their album name and track number. It doesn't matter if the iPod screen is cracked or faulty, or the battery totally knackered as it will be powered through the USB and controlled by the Sync computer screen.
  6. Original, factory fitted pads fitted to my 2018 ST-Line 2.0 TDCi AWD.
  7. niceonept
    Looks good, but aren't you worried about getting pulled over with those black number plates?
  8. Have you checked your brake pads? The Edge uses a mechanical wear indicator comprising a metal prong that makes contact with the brake disc when the pads are at their wear limit. It makes a horrible screeching noise.
  9. niceonept
    First clean of 2021....and more
    It's stopped raining at last, meaning I've finally been able to get outside to wash the new Edge and take some pics. (edit: some newer pics showing wind deflectors and UK instrument panel now added)
  10. I never realised how complicated these things are! All credit to you for working out the fix.
  11. They protect the rims but I'm not quite sure about them.
  12. Fitted a set of "Rimblade" wheel rim protectors. Got fed up with scratching the alloys on my ST-Line!
  13. That should work too. I have a lot of my iTunes music loaded onto an old iPod Touch (which is essentially an iPhone without the phone bit) and it works fine.
