rbrb2008
About rbrb2008
rbrb2008's Achievements
  1. Hey thanks for your input. I recently changed the BAT & it's around 1.5yrs old. I also use the Blue Chip in the OBD using Android Monitoring and it's a constant 14.8 vdc while engine is running.
  2. rbrb2008
    These are Nice! Are the HID-LED Halogen?
  3. I have a 2015 Ford Edge Titanium and it's loaded. Most conversations and on YouTube I'm finding is mostly earlier model edges and if it a Titanium after 2015 very little knowledge of any replacement parts or problem resolutions. Has anyone ever had to replace the blend actuator or actuators on the HVAC? This ride has 4 actuators 2 on each side and addressed as (A) and (B) actuators- one of each on both sides. I guessing that's due to having the dual option. Note: many suggest removing the panel at your knees under steering wheel for access but mine has an airbag there. Any help will be appreciated.
  4. 2013 Edge Limited 3.7 I found this alarm using Blue Driver-ALARM B1215 indicating a voltage short: Anyone ever had this issue? Faulty USB Cable and Port No Secure Digital (SD) card present USB Cable and Port harness is open or shorted USB Cable and Port circuit poor electrical connection Faulty Accessory Protocol Interface Module (APIM)
  5. rbrb2008
    rbrb2008
    DRL Installed 2013 Edge Limited.
