Sorry if I wasn't clear in my OP.
I'm not having an issue with the files per se, but the fact that I think I downloaded the wrong ones.
I upgraded from 18005 build to 19052 of Sync itself successfully. Here is the autoinstall.lst file from that (see screenshot below).
However, at the same time I was doing that, I had kicked off the download for the map update. The map update thought I was still on version 18005, and so I got the map files associated with that build. I've attached the autoinstall for this as well.
I think I'm getting error LST_ERR05 because the license file and map files are expecting Sync build 18005 and the Edge is running on 19052.
If I re-download from the order, won't I still get 18005 since that is what I ordered? Is there a way to get 19052?
I'll give the cyanlabs process a whirl since I need to upgrade her to 3.4 anyway.
