AllFordsForMe
About AllFordsForMe
AllFordsForMe's Achievements
  1. Thanks for the suggestions. I want to swap both to go with the Sport look. I did find the LED option online, but 3 Benjamin's is a little steep.
  2. Been looking to swap my tail lights on my 2010 Limited. Don't want to go 2011 or newer lights because I don't want to mess with the wiring. Why does every part site say 2010 Sport tail lights won't fit? Pics I've seen look the same. What am I missing?
  3. So did some more internet searching and it turns out the wheels I have are from 2011. When I search it on web sites, it is not offered for 2010, leading me to believe there is something that isn't compatible. Bummer... look like I need to sell them.
  4. They don't appear to be bent. There is no wobble or vibrations. It is a rattle like something is loose but i have the lugs torqued to 100 lbs. It happens immediately at 10-15 MPH, worse when I hit any bumps n the road. The noise totally stops when I hit the brakes. Thinking that the wheel isn't holding the brake rotors tight and that's whats rattling. Weird..
  5. Bought some used sport 22's to run on my Edge Limited AWD. I believe I have a hub issue. When they are on the vehicle it sounds like the front end is going to rattle off. Every forum I've read say they will fit. Do I need to install some spacers or hub centric rings? Thanks for reading!
