Boy do I have news, last weekend I went to the field and the car continued to show the same symptoms, when I run a little more than 100 miles the half moon broke and affected the engine block so I had to resort to buying a used engine but with warranty and all its accessories, compressor, hydraulic pump, generator, coils, all its sensors, including oxygen sensors. Perblue, you're right, the first thing I should have demanded to be changed must have been the oxygen sensor. What are you talking about "O2 Sims" what does it mean?
The catalysts are now clean, nothing through there, they are only a tube, now, that could generate the problem? Between today and tomorrow they will mount the new engine and I will try to see how it is, I definitely thought about buying a CRV but just as I made the investment that came out of the opportunity (1,200 dlls approx) then I will stay a few months to see how it behaves And I already tell you, hopefully the fault will be fenced, otherwise I will investigate the gasoline pump, which is the only thing missing to change the vehicle.
Many thanks!
