I have a 2007 Ford Edge AWD SEL 3.5 L with 180,000 miles
Last time I drove it, multiple times the rpm surged 1000 over, stayed there for a few seconds, then dropped down to normal. While this surge was happening, no acceleration was attained by pressing the gas pedal.
By the time I got to work, the car barely moved when giving it gas. This happened all of a sudden, no previous symptoms such as grinding or slipping gears.
It can easily shift into any gear with no clunking sounds, but doesn't move, just feels like its in neutral. There is a strange hollow sound when giving it gas but no other notable sounds or movement. When giving it gas, the rpm stays high for a few seconds after releasing the pedal, then drops down to the normal idle rpm.
I've replaced a few parts over the last year:
-Spark plugs and coils
-PCV valve
-TSS and OSS sensors + fresh ATF (the old ATF was clean though) -- When I took it apart, the screens appeared clean in the case
-MAF sensor
-Throttle position sensor
I can only guess what is wrong with it as there are no codes or check engine light.
I did have the MAF sensor uplugged for a month or so, and to explain why, this is my previous post (different problem, never quite solved it and it could be related somehow). It has been plugged in recently though.
https://www.fordedgeforum.com/topic/28502-vibratingshuddering-while-accelerating-around-a-corner-at-lower-speeds-oddly-remedied-by-unplugging-the-maf-sensor/
Any insight or even wild guesses are greatly appreciated.
