Namroloc
Everything posted by Namroloc
  1. Hey I’m a 2016 Ford edge owner I am trying to change the PTU fluid I noticed this one has a drain plug where others before me you have not, how much fluid should I put in after I drain it?
  2. In process of pulling PTU. thanks for the feedback, I’ll post the few pics I have of this PTU Casing crack/break “in-vehicle” ,...once I get it out I’ll post more clear pictures of the damage. ...this is ridiculous. Just purchased in September 19.... just can’t believe it ...according to ford literature they rectified previous PTU& drivetrain extended issues. When it “changed the Issue with AWD PTU design” in 9/16. yeah... my ass
  3. Thanks for the tips!.. truly excellent ,.....MY 16’ Edge PTU housing just CRACKED IN HALF! At 35mph shifting from 3rdto4th gear, normal Speed acceleration. Just heading to dinner after a movie. slight thump/3second grinding sound , ‘puff of grease smoke&smell simultaneously Thru the vents,...then nothing. Noticed slight vibration at high speed “coasting” in traffic on way home that same night. -79,000 miles, -2nd PTU , - never figured the whole casing would crack open like an egg, no warning or indications of an issue up to then. holy crap on your gearset... unreal...
  4. Hello All, Firstly, I adore my AWD 3.5 -16’ Edge. It’s Power, it’s Handling, the premium leather interior, the ‘M’ shift feature!,,,I could go on and on. Now to my Title Issue —-A vibration set up, (2weeks ago). Basically while ‘coasting’ it began “@ speed” to make a rubbing or light grinding sound. (There was also a light but persistent ‘odor’ sharp & smoky began. It was more evident when at rest, at a light, or while parking?) I thought —‘ok 78,000 miles likely CVjoint’...so I purchased it. I took apart 25% of the right front. NO bad CVboot inner/outer? I Couldn’t understand it. So since my vehicle was, (obviously), “up” I looked underneath, around at the driveshaft it appeared to be rubbing the ^upper^ heat shroud that’s continuous >>>back the rear wheel >>drivetrain>> ‘Channel’? That seemed very strange. I checked the joints (seemed loose )and noticed a bit of what smelled like bearing/joint oil on the Exhaust-pipes. I put the wheel assembly back together. I returned the CV axle. The following day enroute to a movie at low speed 40-45mph, there was a short “grind-clunking” sound and a brief cloud of blue oily smoke came thru the vents and dissipated. After this (for a few days of local driving),...A vibration began “at-speed” when I let off the gas....Not evident or discernible while accelerator was applied SO!! I believed the driveshaft center bearing seals had blown out.(somewhat common according to Videos online )..while trying to install it , (w/ the entire vehicle upon j-stands this time), I noticed UNBELIEVABLY! !,.... The PTU is literally cracked open! what the hell. Has ANYONE ever seen this or had this occur on their Edge? Advice or info is hugely appreciated. Thankyou in advance, Sincerely,
