vtchopperdude
About vtchopperdude
vtchopperdude's Achievements
vtchopperdude replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
I'm in south GA, and it's in the high 90s and high humidity when it has trouble at idle. -
Ya, it definitely has a variable speed. I turned the car on last night, with the AC on. The fan was running. After about 5 mins, you hear the fan kick up to a higher speed, and sounds like a jet taking off. So, the variable speed seems to be working. What else could be the problem causing warm air to blow at idle/traffic stop???? -
Ok, maybe I'm a dummy, but I feel that I'm am above average when it comes to doing mechanical stuff. So, I have the EcoBoost, and there is only 1 giant fan, not 2 fans. And the giant fan spins immediately once the car is turned on with the AC going. Is it variable speed? Is that something that I should check for? -
I'll check this morning. Just wanted to make sure it wasn't some voodoo magic. I figured if the fan was not working properly, the dealership would have caught it when they serviced the AC. -
How difficult was replacing the fan assembly? My Edge is doing the same thing! When sitting idle or coming to stop at a traffic light, the AC starts blowing warm air. We JUST had the system recharged, but they didn't say anything about the fan having issues. I'm thinking this is what's going on. Is it obvious if the fan assembly isn't working properly or cycling correctly, or would I need a code scanner? -
They just didn't hook it back up! I was able to see water dripping out of the tube behind the center console onto the tunnel, and it was just pooling in the floorboards. It was as easy as reattaching it once I figured out that was the problem. But because the carpet and sound deadening material soaked up the water, it took 4 hours of my wife driving on a trip for me to realize that water was pooling. Long story short, they dried the carpets out, and detailed the inside. All is well, so far...... -
Welp, finally got the car back after dropping it off to fix the standing water issue in the floorboards. Interestingly enough, the center console USB starting giving the "excess power draw" warning following the water in the floorboards incident. The dealer didn't remove the carpet, but used some sort of heating element to dry everything out in the car. They also replaced the USB port in the center console, and detailed it. Hopefully the saga of returning the the dealer for poor repairs is over! -
Wow!!!!! F! M! L! We finally got the water pump issue worked out! Pump seized, shredded the serpentine belt, and caused some power steering issues. That got all squared away after 2 visits to the dealer. Well, remember how I mentioned that we had issues with no warm air several months back, and it took them 2 weeks to diagnosis it as a bad valve, which subsequently caused debris to get into the heater core. Well, they had to completely remove the dash, and in doing so broke multiple trim pieces. They replaced those at cost (thankfully). Now the real kicker! Apparently they didn’t reinstall the AC drain tube properly, so all the condensation was leaking directly to the floorboards. Well, considering my wife was only driving it a few miles back and forth to work, it never dripped enough to be noticeable. Well...she drove down to FL on a 4 hour trip, and when she arrived and got out of the car, she noticed standing water in the passenger side floorboard area. OMG! I thought it was the heater core that was just replaced. I did some more investigating in the hotel parking lot, and after watching some YouTube videos, found the drain tube behind the dash and it was not connected. So, for 4 hours all that AC condensation was just dripping into the floorboards. Standing water!!!! What the f**k!!! Do I even take it back to this dealership and let them mess something else up? What are my options? I’m pretty sure the carpet will need to be replaced because it is drenched on both driver and passenger side! -
I'm about at wits end with this dealership! What makes it really crappy is that their customer service is EXCELLENT!!!! I mean EXCELLENT!!! Their communication is great, their hospitality is great, their attitude is great, and the service desk guy I deal with is great!!! Buuuuuuuuuuuutttt, the service is HORRIBLE!!! The worst I've ever seen!!! And I drive 3 Ford vehicles (F150, Edge, and Mustang). My whole family is a Ford family. My grandfather worked on the assembly line installing steering columns for over 30 years. My grandma still receives a Ford pension check every month and my grandfather passed about over 20 years ago. I reallllly want to put faith in this shop (only Ford dealer in town) that they can fix it right this time....but 5 times!!!! What the heck!!!! -
Well F**K MY LIFE!!!!!! Got a call from the dealer. Water pump replaced and car is ready. Go to pick it up. We get about 5 minutes down the road and my wife is flashing the lights at me in the rearview mirror. Well........I walk up to the car and I smell something burning. The dash has about 5 different warnings...battery, overheating, power steering, check coolant, and something else. I pop the hood, and the smell of burning rubber hits me in the face. The serpentine belt is shredded, and the coolant reservoir tank is overflowing. As I said...F**K MY LIFE!!!!!! This is the 5th time we have taken the car back for them to fix their mistakes!!! Granted, they fix it on their dime every time, it's still super FRUSTRATING to waste my time to keep taking it back for improper repairs!!! So ya, my Friday just got sh*t on!!! -
Add a Shelf To Your Center Console
vtchopperdude replied to Gadgetjq's topic in Accessories & Modifications
Cooool! -
And ya it's a great car! It's my wife's daily and we use it for traveling! It just seems like all these problems are starting to pop up after we hit 100k. -
Ya, we are the 2nd owner and treat it like a new car. Purchased with 72k about 2 years ago. It has 102k on it now. Well, after we had the heater core replaced about 6 weeks ago (whole nother story there!!), I noticed a burning smell after getting out of the car. I thought maybe the new coolant they put in was just smelling funny during breakin of the new heater core (is that even a thing??). Well, I came home to huge stain on the driveway a few days ago. I pulled the plastic belly pan and the sound proofing material was soaked and lots of coolant residue on the plastic. I suspected they messed something up with the heater core replacement, but noticed the leak was coming from around the pulley area. The part they replaced for the heater core job was on the opposite side of the engine. So, long story short, big puddle on the driveway; took it back to Ford this morning; they called said water pump is going out. It leaked about a 1/2 gallon of coolant before I noticed it because that huge belly pan soaked up alot of the leakage. They quoted me around $700 total. Seems pretty steep for a water pump, but I'm slammed at work so I am just biting the bullet and having the dealer replace it. After all the crap that has gone on with the car, it makes sense for them to do it because they warranty the work for 2 years. -
water pump went t*ts up on me...
