Jseda
Everything posted by Jseda
  1. Hello Candurin, by any chance did you find a solution for this..? i just change to sync 3 in my edge sport 2011 and have the same like you in the IPC , the radio, sirius and cd , did you figured it out how to add the usb and BT stereo??
  2. Yes , You can buy a 8"screen system from the scrap yard to do the swap.! you will need a few more parts. if you want to upgrade to Sync 3 you will need the 8"screen, Apim module, 8"opening front face console, GPS antenna, USB hub, etc.....
  3. Hello All.. I'm want to upgrade my Sync 2 radio to Sync 3 In my Edge Sport 2011 Also I would like to have version 3.4 installed..! My question is which years is better to get the APIM Module..?? 2017-2018-2019 ?? I read something about the first version modules around 2016 came with problem and read about some 2019 modules K and L series Ford has started using the newest "K series" or "L series" APIM modules. K/L series APIM modules have added data blocks for programming that the older 2016-2018 So the 2019 K or L modules can't been programmed?????
  4. Hello All.. I'm want to upgrade my Sync 2 radio to Sync 3 In my Edge Sport 2011 My question is which years is better to get the APIM Module..?? 2017-2018 ?? I read something about the first version modules around 2016 came with problem and read about some 2019 modules K and L series Ford has started using the newest "K series" or "L series" APIM modules. K/L series APIM modules have added data blocks for programming that the older 2016-2018 So the 2019 K or L modules can't been programmed?????
