Hello Candurin,
by any chance did you find a solution for this..?
i just change to sync 3 in my edge sport 2011 and have the same like you in the IPC , the radio, sirius and cd , did you figured it out how to add the usb and BT stereo??
Yes , You can buy a 8"screen system from the scrap yard to do the swap.!
you will need a few more parts.
if you want to upgrade to Sync 3 you will need the 8"screen, Apim module, 8"opening front face console, GPS antenna, USB hub, etc.....
Hello All..
I'm want to upgrade my Sync 2 radio to Sync 3 In my Edge Sport 2011
Also I would like to have version 3.4 installed..!
My question is which years is better to get the APIM Module..??
2017-2018-2019 ??
I read something about the first version modules around 2016 came with problem and read about some 2019 modules K and L series
Ford has started using the newest "K series" or "L series" APIM modules. K/L series APIM modules have added data blocks for programming that the older 2016-2018
So the 2019 K or L modules can't been programmed?????
Hello All..
2017-2018 ??
