selfmade6288
Everything posted by selfmade6288
  1. Removed overhead BAMR switch and cleaned the connections, reassembled, reinstalled... GLASS WORKS! Sunshade still stuck in closed position. Fabric appears tighter on driver side and looser on pass side? Any ideas? I have not dug deep into the issue due to the weather but its getting warmer now! Not "check" light for brakes, I was incorrect with that statement. Only TPMS check light is on. Looks like this: (!) Will any brand/type/style aftermarket tire pressure monitors work OR do I need to search for vehicle specific ones? Does all of the monitors have to match?What is the cheapest solution assuming that all 4 TPMS will be required?
  2. 2010 Edge LIMITED, 120K+/-, owned for <30days. Have driven about 1k miles since purchase. Check Engine light has come on, showed 4 Codes: P0451 U0253 B2290 B1318 2 nights ago I drove <20miles during HEAVY rain, Edge was NOT driven through high water, but there were 3-4 places where water splashed/sprayed up while crossing. (Never heard that ominous of water beating undercarriage!) Parked having no issues. *May be unrelated: Opened remote start fob to change battery, seen the 1pc metal contact was loose on 1 side, put metal back into place, reassembled. (Brand unknown) Yesterday morning was cold maybe 20 degrees Used "repaired" fob to remote start. Rear Brake Aid On/Off & Driver Door Adjar were both lit up. Brake notification went out after taking off, Door note stayed on and int. lights were all on. (Opened/closed all doors 2x). After 4hrs Door notification was gone. This morning CEL was lit. Had codes read *see above*. Have been searching for info related to codes, possible trouble shooting ideas, how to determine which part is throwing which code, HOW TO FIX? Please let me know what will repair all this. Thanks Matt
  3. Where are the tpms sensors be located and do you have a photo or diagram of how it looks? I know I can find them once I know what im looking for lol. Aftermarket wheels seem pretty cheap so I am hoping that when they were installed that PO did something incorrectly. Can I have the codes read at an auto parts store? Many do it at no cost around here and give print-offs of info relevant to code. What does BAMRF mean? I am thinking it is the switch preventing moon roof from operation since I do not hear ANY of the motors associated with shade or glass. How many total motors are in that system? 2 for glass & 1 for shade?
  4. New to forum, just bought used 2010 edge limited fwd 120k. Brake light stays on and wheel air pressure notification stays on. Previous owner has installed aftermarket wheels. How can I go about diagnosing the issues causing the light/notification and repair? Also the panoramic moonroof & sunshade both are stuck in the CLOSED position. I do not hear ANY motor noise when pressing either button. Fuses appear good... but plan to get new fuses just in case. I'm not a mechanic but can do pretty much anything with some basic instruction. Have seen videos ect on "initialization" and followed steps but nothing happened. Held button, roof never moved, shade never moved, neither made any sounds.
