gern
About gern
gern's Achievements
  1. Sorry, forgot to reply to your second question. It is possible to bleed brakes with tire on but so much easier when you take wheel off and looking at the bleeder. I forget what size the bleeder screws are but the ones in the front take slightly larger wrench to open than back.
  2. I can tell you what I know of the program but Forscan forum is the best place to ask. The abs test is where you would bleed which activates the system. I use a pressure bleeder to keep pressure on the system as well. What kind of problem are you having?
  3. So far, bleeding my brakes has fixed the problem for me. I did not do an abs bleed, just at the calipers. If my problem comes back however, I will do an abs bleed as well. I use the Forscan program to activate the abs to perform this function. My pedal went to the floor as soon as I drove off from the dealer after the booster was replaced during the recall. The dealer had to bleed brakes several times to bring up pedal to my satisfaction. I wouldn't know what steps they are taking to figure it out for your vehicle but bleeding the brakes plus abs would be one of the first steps to take when there is a pedal that displays air in the system. My first thought on my pedal was a bad master cylinder. I went ahead and ordered a new one but decided to do the brake bleed while waiting for the part to come in and so far my pedal is staying up.
  4. New to the forum, just throwing out some thoughts to the Ford Edge brake problems. I have a 2012 Edge Limited bought new in 2012. Sometime in 2015, the brake booster went out and was covered by the dealer due to the booster recall. When I picked up the vehicle after the repair and drove away, the brake pedal was spongy and went to the floor. I turned around and went back and was told by their service guy it was normal. It wasn't normal and obviously had air in the system. Spoke to the manager and issue got resolved. Today I experienced the same spongy pedal that went to the floor, no brake light or abs light came on, no leaks. My first thought was master cylinder, and it still may be so I ordered a new one today. Checked and found no codes present or pending. In the mean time, I decided to bleed out the system to see what would happen. Bleeding out the system brought back a firm pedal with good breaking but will it last? I have read on many forums where the 2011, 12 and maybe other years as well where experiencing the same issues with the brake pedal going to the floor and mechanics where unable to reproduce the issue and where chasing parts to figure out what the problem was at great expense to owners. I do my own work but still do not like chasing parts to figure out what a problem is. If anyone is interested, I will update on whether the bleeding solved the problem but I will still install the new master cylinder as a precaution.
