Duece McCracken
    12
1 Follower
About Duece McCracken
3,870 profile views
Duece McCracken's Achievements
  1. Ok, ditching the Edge. Rims and tires for sale, intake for sale, SCT BDX for sale. Only have an ad up for the rims so far.
  2. Everybody needs a win, here and there. Lol! Nice work on the structurally appropriate mold!
  3. Yes, I gathered all that, but you havnt actually put it in a car yet? C'mon meow!!!
  4. Ohhh, its an adapter, not a whole bottom airbox!! Could I run this with your lower? Like a mad man!!
  5. Well, Looks like Im going to have to buy this version too. Lol
  6. Thermo-Tec 13575 Adhesive Backed... https://www.amazon.com/dp/B0844NGHS6?ref=ppx_pop_mob_ap_share One of these does the whole bottom. I used acetone for surface prep, and Thermo-Tec 12005 Spray-On Adhesive - 16.75 oz. https://smile.amazon.com/dp/B000P76ES0/ref=cm_sw_r_apan_glt_i_RK2R0ZKP0G9PDFR7DMEE To try and stick it real good. Lol Time will tell. I had shears and an Exacto knife setup, a couple of flathead screwdrivers for tucking. If I had to do it again, I'd probably scuff up roughly, the box bottom first. Then clean and hose down with glue, lol
  7. Oh geez, cool tec or some shiz. Whatever @Xtrarecommended, lol.
  8. This is on my 2015 Edge Sport AWD. Airbox takes a bit of manipulation to clear the Large locking connector at the drivers side fuse box, besides that, fit right in. Old K&N drop in filter was pretty clogged, and had large debris on it, so right off the bat, this is going to breathe better, not to mention the much larger volume of filtered air. Going to run it today/tomorrow, then probably reflash my tune and see if the ECU can learn anything better with this airbox.
  9. Well, finally wrapped it. Just have to clear the drain holes out, and she should be good. Not the best job I've ever done, lol, but it'll work.
  10. Oh geez! I've had it for months now, never installed it!! I need to get on that!!
  11. Popped a P0430, and its sticking. Bank 2 Cat low efficiency. Im going to change that rear O2, and start looking at going catless. Also P05A1 which is an active grill shutter position code. I still have the motor plugged iirc, i forget. Going to have to look in this build thread, lol. Also Northstar battery ate it. I didnt do a proper BMS reset iirc. Swapped in an XS Power agm. Same upsize
  12. Oh, and body shop commented on the CF intake cowl! Additionally, they started asking questions. "SO what all did you do to this? Lol" They got excited over seeing the aftermarket parts on it, lol
  13. Hit and run damage. It's not much, but WTF man. In my cul de sac, over thanksgiving weekend. Douchery SOrry for the terrible lighting. A buddy of mine owns a body shop, got me a fresh OEM bumper, installed my aftermarket lower grill, paint matched, all that good stuff. Took him 5 days to get the bumper, then it was done. So a week total. Once I get back from Xmas, I'll finally wrapp the @Xtra airbox and install it!!! I need to do an oil change too, lol Im going to clean the two grounds on the frame under the airbox as well. I need to do all the driveline fluids. Rear diff, transaxle, PTU. I need to do research on that though, what fluids and what not. Cross reference with the owners manual for specs.
