dajo2012
Everything posted by dajo2012
Tail light Condensation
dajo2012 replied to d0minicano's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
My 2020 manual gives a definition of what is excessive if defined as excessive it should be taken care of by Ford I would think. Maybe your manual has this also. Document for $200 that is really big of them. -
anyone here use an impact driver when changing wheels?
dajo2012 replied to ben senise's topic in Wheels & Tires
I use my old Dewalt impact and it is not even the higher powered ones they sell now. -
2019 edge st 2019 Edge ST--replaced the odd-shaped exhaust tips
dajo2012 replied to Jombi's topic in Accessories & Modifications
Now it looks like any Edge, not unique anymore like the ST. That exhaust is how I can tell if a distant Edge is an St, but since the addition of the ST line it no longer means anything. -
Because I have actually looked at mine there is not any extra injectors. Just the original DI injectors (6).
Not true, the 2.7 still does not have dual injection.
I went to the school last Wednesday in Asheville. Fun to abuse a car just like mine. Worth going to, would like to have had more time on the track, day is only so long. Does't seem to be much interest here on the forum.
Can I disable artificial engine sound in cabin?
dajo2012 replied to Jombi's topic in Interior, A.C., Heat, Interior Trim
My 2020 does not seem to have it. I have never heard one with the piped in sound but all I hear is engine winding up a very pleasing sound to me. I would like to hear the ANC it if someone could post video. -
Does the tune give more accel say up to 30mph? My ST is less than impressive off the line. Can a person get the 87 tune and make an improvement here. I have the unleashed tune in my F150, currently using the 87 tune and can't really tell much difference but is feels like it is quicker that the ST.
Adaptive headlights
dajo2012 replied to Itsdjellz's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Same as my 2020 ST. -
Auto Stop Eliminator For The Nautilus
dajo2012 replied to handfiler's topic in 2019-Current Edge & Nautilius
Nothing to do with park. It just shuts of to quickly and doesn't give me a chance to move forward the last few inches. Yes I know I can shut the engine on or off, when shut off it goes into park automatically. Nothing like your F150. -
What I really don't like is when pulling into garage or parking space it will shut off and back on. The brake pedal pressure is very sensitive that triggers the start stop. -
Turn signal switch
dajo2012 replied to Mike388's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The first place to look is where you just worked on. -
I just had my battery out and ran wiring through the grommet. Grommet is behind all the brake lines behind the battery tray, easy to see and a pain to get to. The grommet is larger than the wire harness already going through it but is very tough and hard to penetrate since access is so hard. I failed to be able to put a hole through the grommet. Dash side is not much better. Maybe someone younger can do it.
dajo2012 replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Something you can actually see without being eight feet tall or in an airplane. LOL -
Those of us that tow our edges behind MH disconnect battery for towing as required by Ford. There is a kit from Roadmaster towing to install a latching relay operated by a push button switch for battery disconnect. I just installed one on my ST. They disconnect the positive cable since the negative is so difficult to reach. They have been making this kit for quite a while. I am not concerned at all disconnecting the positive cable, but of course no wrench on battery terminals everytime. https://www.etrailer.com/Accessories-and-Parts/Ford/Edge/Roadmaster/RM-766.html
It would be nice to know some car information like year, engine, etc
I have my front fascia removed now to install tow plates. The Ford emblem has two protruding studs with a nut screwed on from the back. The L shaped piece has tabs that appeared to be epoxied to the panel it attaches to, does not look like removal possible without breaking something. Removing the front is not that bad, many small screws and plastic push pins. Several wiring connectors on the driver side. Washer hose on the passenger side. Headlight removal is required first.
Can someone tell where the sensors are for opening rear hatch with foot motion. I have the trailer hitch so it should open either side of the hitch. Does it use the sensors on the bumper, I don't see any sensors of any kind around the sides of the trailer hitch up under the car.
2012 Ford Edge Limited Battery message
dajo2012 replied to lieufire's topic in Audio, Backup, Navigation & SYNC
When I had issues with my F150 BMS. I hooked the charger - cable to a ground on the body and not the battery -. Never had to reset anything. -
Thank you for doing all the work on this useful information.
The only thing I hear when unlocking is the doors unlocking, no other noticeable sound.
Your build date is on the window sticker near the bottom center.
Member's details not shown anymore?
dajo2012 replied to handfiler's topic in Forum Help & Site Suggestions
Where do you find the signature to add year and model?.
