dajo2012
    2
Everything posted by dajo2012
  1. That is exactly what my 2007 Ranger did when the fuel pump was failing. New fuel pump no more issues starting.
  2. The Ford experience scenic mountain drive I went on in Ashville was a slow follow the leader drive. No chance to try anything since the speed limit was 45 mph and public road. The rest of the driving was a good experience. Maybe the other locations offer a better drive.
  3. https://www.etrailer.com/Best/1453/Ford/Edge/Accessories_And_Parts/Auto_Battery_Disconnect?year=1949 It disconnects the positive cable since negative is so difficult to get to. I have one on my ST and several on the rv forums use it also. It takes more than a bolt removal to move the battery far enough forward and even then not enough room to work. Shop around on price some are better than E-trailer but they will price match.
  4. I got the idea that it was to show drivers who had completed the Ford school with black instead of the usual red.
  5. For what is worth when I went to the ST school they gave us new black ST emblems.
  6. If you had the cold weather package it would have a heated steering wheel.
  7. How old are your tire sensors? Wondering when this will pop up on my 2014 F150 about ready to get new tires at 52,000.
  8. The problem with one listed on ebay and most other places is they have a gap under the oem visor right where you look through. I just bought one from Auto zone and it is useless since it leaves a 1 1/2" gap right where I look through. It was $9. Still looking for one.
  9. My alert has come on a couple of times. It seems to be when a car crosses in front and sometimes at an angle. Never had any braking just the alert. Alarm is plenty loud and a different sound than others. The passenger seat alarm is much louder and way to sensitive.
  10. We did this at the Ford driving school using a device that looked a little like the rear of a car. We made several runs at it a 20 mph IT WORKS GOOD. Not easy to intentionally not use brakes but fun to do with someone's car.
  11. Maybe that is why I consider my Edge disappointing in performance. When at the Ford driving school doing the timed section it seemed to loose a lot of time at the start.
  12. I tried it a couple of times and then shut it off. The car is so smart that if you remove hands from steering wheel it will alert to put hands on steering wheel. Park assist is fun to play with and it actually works good, try it out at least once. The other thing I turned off is the auto dim headlights, found that they would dim to often even when bright reflector type signs were ahead.
  13. I thought all safety glass was laminated. Isn't that what makes it safety glass with two layers of glass with a clear vinyl layer between. If the ST is different how is it different?
  14. Must be having a slow Thanksgiving today.
  15. corrosion, corrosion, corrosion Has the coolant ever been changed? That is a mess no wonder pump failed. what year car and how many miles?
  16. Just emptied my JLT after pulling a Uhaul from Indiana to AZ with my F150. Used boost a lot more pulling trailer. Can was about 2/3 full with 1/4" white gunk in the bottom.
  17. I have the JLT in my ST and my F150. Both are very easy to remove can to drain using JLT recommended location. Both are catching oil. I just can not pay the high price for the more complicated system. Install of JLT is very easy.
  18. If you keep banging on the starter you better hope that the windings are not glued on and you don't knock them loose. Your going to need a need a new starter anyway. Banging on these newer starters is not a good idea.
  19. https://www.fordservicecontent.com/Ford_Content/Catalog/owner_information/2019-Ford-Edge-ST-supplement-version-1_su_EN-US_08_2018.pdf 2019 but still close
