JTW
About JTW
JTW's Achievements
  1. Synthetic Blends only have to have 5% synthetic base oil in them to be called a "Synthetic Blend" oil. It's a waste of money in my opinion. A full or 100% Synthetic oil is much better than any blended oil.
  2. It;s the hydraulic control unit on the ABS module. They have a tendency to have a internal valve stick open and allow fluid to bypass the calipers.
  3. The hydraulic side of the ABS Module has an issue of a valve sticking open inside allowing fluid to bypass. You can replace the HCU and it will take care of the problem.
  4. The problem is with the HCU, not the master cylinder. I found a company on Ebay that rebuilds the HCU. They will ship you a rebuilt unit with all the problems repaired and you send your bad one back.
  5. If everything is fine with the oil your using, why screw with it? A good synthetic oil does not need any type of additive to make it better. Adding a additive may have negative affects on the oil chemistry and also void the oil companies warranty.
  6. My trans fluid always comes out dark. These transmissions only have an internal screen for a filter. No way to change them unless you break into it.
  7. I have over 160,000 miles on my 2013 2.0 and have only used Amsoil 10W-30 Signature Series oil. I change it every 10,000 miles. I also use the Amsoil oil filter and have done used oil analysis to confirm oil is good and nothing is wearing. So far I have had no oil related issues.
  8. Why would backing be any different than driving forward?
  9. That's pretty much your preference on what shocks and struts to use. I like Monroe but there are many to choose from.
  10. It makes me wonder if they reset the parking brake. The caliper pistons have to be reset into the caliper or the new brakes will drag on the rotor.
  11. If you haven't already, go to a Ford Dealer site online and look up your vehicle and enter your Vin number to look up the correct module. Why are you suspecting the module as the problem? Is there a MIL?
  12. All you have to do to remove it is to remove the cat and there is room to pull it out.
  13. 2013 Edge Limited 2.0 Ecoboost, 134000 miles. Has been losing freon for several months and bad smell from vents at start up. I've just been topping it up when it starts blowing warm. I decided to repair it since wife is on my back. No leaks out front so figure its evaporator. I ordered the whole evap case from Ford along with a new condenser and compressor from Rock Auto. UAC Brand. After gutting the car to install everything, I pulled a vacuum on system and it held overnight. As I started to charge the system, the low side pressure only stayed static matching the high side pressure. As the pressure rose, the compressor engaged and was running. The pressures did not change though. Low side pressure just slowly rose to around 90 psi and stayed there. No freon was pulled into the system by compressor. The only thing I can think of is that I got a bad compressor. Thoughts?
  14. A low freon charge will also cause what you are describing. Mine did the same thing and found out that the evaporator was leaking.
