kruzr1
Everything posted by kruzr1
I think the heat output is partly dependent on the interior temperature. The warmer it is inside the easier it is to heat up the seat. Personally, I don't use them until it's in the 20-degree Fahrenheit range or less.
I actually got my fluid at the dealer for $6 a quart which was cheaper than everyone else. I used the motorcraft ULV fluid for my vehicle.
Was curious about the splash guards if they are in fact a direct fit for the ST? Haven't found a set myself that said they fit the ST.
[update/conclusion] White smoke on acceleration
kruzr1 replied to ben senise's topic in 2.7L EcoBoost
I have a 2019 ST with about 29000 miles. I get the white smoke also but I'm thinking it's because of temperatures. Only ben in the 20-degree Fahrenheit range for highs lately which is what I contribute the white smoke to. I do not recall seeing the white smoke during the summer months? Every other car I observe also has white smoke coming out the tailpipe. Some more than others depending on the vehicle. This is typical here. My coolant level is about the same as 1004ron. Although it does change a little from summer to winter I've never had to add any yet. I'll just be keeping an eye on it and hope it doesn't amount to anything. I was planning on having the coolant changed out next spring to Fords newest coolant. When I bought the ST I figured the 2.7 engine was a proven platform since it had been around several years. Hope it doesn't get added to Fords list of troubled engines. -
I was wondering if this noise can be identified separately from other noises under the hood? Such as the high pressure fuel pump and with the hood closed and an engine cover on top also. The only unusual noise I hear once in a while is a metallic sound when starting, more like a noise that would come from starter engagement? Basically just wondering if this is something that would definitely be noticeable and if there's any other factors involved such as mileage and age of vehicle.
2019 Edge Titanium forgets dash settings
kruzr1 replied to AcousticTheory's topic in 2019-Current Edge & Nautilius
The Auto Engine Off in the IPC has nothing to do with the auto start/stop. It's a safety feature that shuts the engine down after a certain amount of time. Like in case you forgot to turn it off. Usually you would turn this off during a sync update. It is always on by default after a key cycle. -
welcome to the forum
Going to add another possible noise source to check. There's a little grille cover over the rear microphone for the ANC system. On my vehicle this easily comes off. When I tried reattaching it, it doesn't seem to want to clip on but makes that creaking type noise I've been hearing as I push up on it. I've been driving around with it off and that irritating noise I've been hearing is gone! Going to try to find a way to attach it so it doesn't make that noise. Kinda ironic that part of the system that's supposed to make the car quieter does just the opposite.
Are you sure it has a lifetime replacement warranty? Never seen a battery with lifetime warranty. Advance auto's website lists 3 years as the longest warranty on their batteries??
I have a Samsung s20 with a protective case and the wireless charging works as intended. I don't see any notices on my cars screen when initiating wireless charging, but the phone does of course. If the phone slides off center too much I get a notice on the cars screen.
Thought I would post this here as a comparison/reference. I recently did a fluid change on my 2019 Edge ST with the 8F57 transmission. I did not encounter any problems that colinc755 had with his 8F35 transmission. I did remove the airbox to get easier access to the fill/vent plug but there was nothing else attached to it, it came straight out. On a side note, I could've probably just removed one of the intake hoses to gain access to the fill plug. The fill plug itself was easily accessible and was held on by a squeeze clamp and came off easy. Neither the drain plug or level plug were difficult to remove, used a 3/8 drive ratchet with a 3/8 hex socket to remove the level plug. I did remove the tire and set the ride height with a jack and stand to get access to the level plug but turns out it can be reached by turning the wheel out. The amount of fluid that came out was 4 quarts and 12 ounces. My work shop manual says this: Remove the transmission vent cap and fill with transmission fluid. Transmission overhaul (includes main control and torque converter drain) Volume : 6.34 qt ( 6 L) Main control overhaul or replace (with out transmission overhaul) Material : Motorcraft® MERCON® ULV Automatic Transmission Fluid / XT-12-QULV (WSS-M2C949-A) (MERCON® ULV) Volume : 5.28 qt ( 5 L) I refilled with 4 quarts and 16 ounces. The hardest part was probably trying to get the transmission up to operating temp. I drove around for at least 20 minutes and also used sport mode to help. When I did get to the leveling procedure, I had some fluid seep out for a bit and then slowed to a drip and I reinstalled the level plug. I have been monitoring fluid temps off and on since without any issues. I don't have a lot of miles on my ST but I believe in being proactive, and as has been said before "no fluid lasts forever". I've also replaced fluid in my PTU and RDU already.
2016 Edge - A/C water Drain location?
kruzr1 replied to omar302's topic in Interior, A.C., Heat, Interior Trim
I have seen water on the ground only once. Other wise I do not, and I check often because I have thought about the same thing. One thing I try to do if I'm parking the car for the day is to run the fan on high with a/c off for a few minutes before shutting the engine off. Sometimes I think I smell something but not sure. Kind of a "musty" smell? -
I believe both fans are supposed to turn on when the AC is on. Not sure why both turn off when you turn the AC off unless the engine has reached a low enough temperature.
They're probably referring to the radar plate mounted on the lower grille.
have you looked at the strut mount or stabilizer link?
My 19 ST use to make this thud noise at around 13 mph. I never took it in because I figured if it was something serious I would get a warning. The dealer probably wouldn't acknowledge it anyway and it's difficult to even get an appointment. Then recently I noticed the sound was gone. About the only thing that has changed is the weather, colder.
Sync 3.4 disables USB browse functions
kruzr1 replied to tk2fast's topic in Audio, Backup, Navigation & SYNC
I have a 2019 edge with sync 3.4 and the latest build update. Think there has been 2 I think. Anyway I can browse my usb drive when parked but not moving. I guess Ford really wants you to use voice commands when driving which is the smart thing to do so you're not distracted. -
I have a 2019 ST and my work commute is 7 miles one way. Some city and highway driving mixed. I average around 22- 23 mpg. During just highway driving I've reached as high as 29 -30 mpg. The higher the speed the lower the mpg obviously. My trip out to South Dakota last year in the 80 MPH speed limit my mpg dropped to about 26 mpg.
That's why I was a little confused when I went to look for a drain plug, and there wasn't one where I was expecting to find it. I believe the fill plug is on the back side facing rear of vehicle and not too hard to reach (forgot to take picture ?) But the diameter seems small and may be difficult to pull all the fluid out. The suction hose will have to be moved around to reach all fluid so not sure how difficult that would be.
Was glad to clear this up a bit on the ST models. I will try to take some pictures in a couple days when it's not raining and not working. So dajo2012 and Perblue, are you saying you changed the fluid on a ST ptu (just wanted to clarify)? Did you use the fill plug to empty and fill? Any other tips would be appreciated ie what extractor you used. Thanks again for the information.
Has anyone with a 2019 or newer ST looked into changing the ptu fluid? I've looked under mine and can not seem to locate a drain plug. there seems to be an external pump? connected with hoses etc to the ptu. I've seen macbwt video on changing the 2019 2.0EB, my ptu setup doesn't look anything like his. I have done searches on the forums and web but not able to find anything specific to the ST. I'll probably go back under and take another look when the weather improves. Thanks in advance for any info.
