68lemans462
Everything posted by 68lemans462
  1. Sorry it has taken me so long to respond.. I'm ready to get serious about fixing this seat and appreciate the information that was shared. Can someone detail the process for performing a self test of the SCME as mentioned above? Also, does anyone know how to check these: Restricted backrest blower motor filter Crushed or restricted backrest foam pad Cushion or backrest blower motor Thanks
  2. Drivers seat is the problem. Its throwing a code B272C-60. Forscan shows the seat back bottom heating up but the seat back doesnt go up in temp. When I press button for cooled seat, I do not hear the fan kick on. I suspect a potential fan failure but this doesnt explain why the seat back doesnt heat up??
  3. I noticed an oil leak on the drivers side of the engine on my Edge with 35k miles while changing the PTU fluid. The leak is not from the oil pan and I'm suspecting it could be the the EOP sensor. (https://ford.oemdtc.com/1321/engine-oil-pressure-eop-sensor-oil-leak-2015-2017-ford-lincoln). Can someone tell me the location of the EOP sensor? The car is still under warranty but I may just fix this myself if its not too bad. Suggestions?
