So i was able to get my DRL to be my running light! I was also able to disable the double horn beep when you leave the car with the key fob. When i look at the link with the nice spreadsheet for the different things you can configure, some of the lines that are listed on the spreadsheet are not in my modules in ForScan, does that mean i can't configure those options then? For example the auto tilt side mirrors when in reverse, i have memory seats and mirrors but the option on the spread sheets says to go to a line that starts with 720 but all i have are 726 lines (the beginning numbers for each line all the way to the far right). Now here is something even more interesting, the remote close window code is already configured correctly, but it does not work with my key fob like the auto down windows do, in my settings i only have remote open there is no remote close option to select. I do have auto up and down window switches though on the inside of the car. Lastly I could not add the climate control into the right dash screen since the code it needed me to configure does not show on my module, I'm assuming i can't do that one either?
