Totally agree with you. Turns out my parking brake actuator on the passenger side was also bad.
Here is everything they ended up doing (also included the front brake hose recall they had to do) including the part numbers they replaced as well. When I looked at the wiring harness for the passenger side it seemed to have some corrosion in the connector, so I believe there was a seal that got compromised and caused this to happen.
Some of my lug nuts were "swollen" so they had to be replaced. I hate lug nuts with caps lol
2016 FORD EDGE
A PERFORM RECALL 20s42 FRONT BRAKE FLEXIBLE HOSE LEAKS
20S42B RECALL 20S42
1 J2GZ*2078*A HOSE ASY - BRAKE
1 J2GZ*2078*B HOSE ASY
1 PM*20* FLUID - BRAKE
4 *W711784*s300 WASHER
87474 20S42B, 1.0 HOUR REPLACE BOTH FRONT FLEX HOSES
1 H2GZ*14A411*A JUMPER WIRING
1 H2GZ*14A411*B JUMPER WIRING
1 DG9Z*2B712*A MOTOR - ELECTRIC PARKING BRAKE
1 E1GZ*2B623* CA SWITCH ASY
10 ACPZ*1012 *M NUT - WHEEL
4.0 hour
scan has multipul dtc, park brake, and switch related, replace switch, replace rt. rear park brake actuator, replace rt. and left rear park brake wire harnesses, clear dtc, road tested
normal operation
