Everything posted by Gadgetjq
I'd be happy if they just told users what an update includes.
My '16 Edge has been plagued by a mystery power drain. After not being driven for a couple of days I kept getting the infamous 'shutting down to protect battery' message. I recently had a 'DOH'! moment as it occurred to me maybe the iPod plugged into one USB port and a phone charger into another plus usb adapters in all the 12V accessory ports were sucking the life out of the battery even when they weren't being used. That issue is now solved with a simple tweak using FORScan. I've set the time out to two minutes (I've no idea what the factory setting was but it was well over an hour and might have been the full 18 hours allowed) you might be happy with one minute or one second or hours. If you want to try this I used the F150 spreadsheet for the setting and it worked fine for my Gen2. Change Power Point Time Out (H/M/S) BCM 726-39-01 **** xxxx xxxx Power Point MaxTime Cfg (seconds converted to hex) Use this spreadsheet link. Adjust the timeout you want, note hex in first column, change BCM accordingly. Cheers!
- 1 reply
Gadgetjq replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
In the original spirit of this thread here's the brief description: I used FORScan to set power point turn off at 2 minutes. More details in the regular Mods section. -
Adding factory tow hitch
Gadgetjq replied to scorpionking0102's topic in Cargo, Hauling, Roof Racks & Towing
Here's the simple answer: Spend some time browsing this section of the forum. Below your message are dozens of threads that detail wiring/harnesses/modules and, yes, hitch options which include your Sport. Note you'll probably never duplicate a factory installed trailering package which includes addtional engine/transmission cooling, an anti sway module (which may be included in the trailer module that would be tucked behind your right side cargo panel) and, of course, a class II hitch. -
Access to hatch wiring is fairly simple. Remove the pull handle on the passenger side of the panel and the screw(s) underneath. After those screws are out just start popping the panels off with a plastic tool or padded screwdriver. Once you get a panel started you can get your fingers under it and just move around the edges popping clips. You 'might' be able to access the reverse light harness with only one panel removed. If not then pull the next one. If you work better with pictures than descriptions download the factory service manual from MacT garage. Here's a link: https://drive.google.com/drive/folders/1Kv_Hsy6bOToW-NiO3ME9mY5TRvoHYKlS
Agree with Omar. Check your Display settings. The color buttons slide up and down to determine brightness. Perhaps they've all been turned off.
It's in your owner's manual under "Driving Aids" : Alert: When active, a flashing visual warning appears and an audible warning tone sounds.
SYNC3 Map Updates Available On Line
Gadgetjq replied to jmr061's topic in Audio, Backup, Navigation & SYNC
Some are advising that we ignore that first 'done' message. Eventually the system continues the update and reboots THEN you're updated. Minimum update time I've seen is about 50 minutes. -
Cargo dimensions rear seats down
Gadgetjq replied to Slamme's topic in Interior, A.C., Heat, Interior Trim
There may be a difference in rear seat leg room. I looked at RAV4 before buying the Edge but it's 4 cylinder only which was a hard pass for me -
Gen2 (2015+) is 72 (give or take an inch) x 45. There's some intrusion into the cargo area from the rear wheel wells. Discounting that you could add another 6" to the width. Length was measured from the inside of the tailgate (closed) to the back of the front seats. -
It sounds like you've deleted the bluetooth connection then added it again already but if not, do that. Check the Bluetooth connection on the phone to be sure you've enabled contact sharing.
I can't tell you whether it'll work or not, much depends on the capacity of your jack but, two things. 1. You'll need a pair of hockey pucks with slots cut in them so you don't crush the seam while lifting ( https://amzn.to/2IqOqel ) 2. HF frequently offers 20% off coupons in their emailed ads. Wait for one of those if you don't already have one lying around and save a few $$$.
Tail light Condensation
Gadgetjq replied to d0minicano's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Actually it sounds like the right side light is working as designed. As your manual tells you some condensation is normal and will eventually clear itself. What 'isn't normal are heavy droplets of water or a sloshing puddle in the bottom of the assembly. Perhaps only your left and center housings need replacement. -
Freebie! This video provides part numbers:
16 Edge Sport - Cannot update Sync - Ford Website
Gadgetjq replied to EdgeDet's topic in Audio, Backup, Navigation & SYNC
Please let us know if you manage to update your system to V3.3 and how you did it. The most recent update I've seen for my '16 is V3.0. I'm thinking you've gotten some bogus information from support but who knows, maybe there's a way -
EdgeDet, You 'should' have another update waiting. It'll be V3.0 and the build that was released last week 19205. With V3 you'll finally be able to use both Android Auto and Apple Car Play on the big screen. If you use an Apple device you should also have Waze as an app without having to use Car Play. -
Sure it would. If a product is still covered by warranty whether it's a tail light or a toaster it'd be foolish for an owner to do their own modification. Once outside the factory 3/36 warranty though it's time for some very careful reading of an extended policy (if purchased) or a little bit of do-it-yourself handiwork. Isn't this one of those 'needless to say' items? -
Plug in a 12v LED (or other low draw accessory) and check it out! If the port doesn't shut off immediately set a timer and check it out every 15 minutes or so. If your Gen1.5 works like Gen2 models the power ports can be set (using FORScan) in increments ranging from on/off with engine start stop to always on. A battery protection system will shut the ports down if voltage falls to a level that could threaten engine start. The OEM setting was something like an hour and a half.
Based on the photos I'd guess you're hoping to purchase via Amazon. That company has an excellent return process if the item isn't what you expected. Bottom line, order with confidence you can return the lights (free) if they don't appear in the real world as they do in the pictures.
- 7 replies
- exterior light
- mirror light
14.7 psi in the cabin (at sea level)
Washed It, wiped down under the hood, checked fluids, vacuumed, checked all lights and added air to all 4 tires (cooling off) then modified system using FORScan so navigation settings can be used by co-pilot while Edge is in motion. Good to go for another week. -
Gadgetjq replied to ben senise's topic in Accessories & Modifications
Disappointing but good to know. Thanks for the feedback! -
Remote Windows
Gadgetjq replied to seanmarshall's topic in Alarms, Keyless Entry, Locks & Remote Start
Yes....sort of. If this isn't already enabled in your Edge you can use FORScan to control both up/down of your front windows via the remote. There's no provision for the roof. Before digging into the FORScan code try these simple steps. 1. On your remote press unlock-unlock-unlock and hold for five seconds. Your windows should roll down. Now press and hold lock. If your doors lock and windows roll up you're already good to go. If not 2. Check your left side info display. Navigate to Settings/Vehicle/Windows. If you see check boxes for Windows Open and Windows Close make sure they're both checked. When they're both checked try step 1 again. If one of those modes is missing (as my window up was) you'll need FORScan to change the following (after you write down the starting settings so you can go back if it doesn't work): Make all of the following changes to BCM, DDM, and PDM modules: BdyCM (As-Built): 726-17-01 0101 0101 014A 726-17-02 0101 0101 014B 726-30-01 0101 0000 0060 DDM: 740-05-01 Dxxx xx PDM: 741-05-01 Dxxx xx -
2018 Edge 3.5L AWD oil drain plug torque
Gadgetjq replied to Dan T's topic in Ford Edge & MKX Member Builds
Hi Dan, The 3.5L Oil pan drain bolt is 20 ft-lbs with a new crush washer. Curiously, that spec is in the "engine removal' section of the service manual, not the engine installation section. Go figure. You can find the complete service manual and a lot of other information at this link from the MacT Edge Garage: https://drive.google.com/drive/folders/1Kv_Hsy6bOToW-NiO3ME9mY5TRvoHYKlS
