Lincoln81
Everything posted by Lincoln81
Wow happy I came across this, took a while to find, I have a 2015 with the 2.0 FWD and we just started to get the parking hill assist / traction fault lights/warnings/ Hill Climb assist and service advancetrac lights. lots of videos of other fixes online for other ford vehicles. I dont have any engine lights yet, and when I turn the vehicle off and on the lights go away, they have come on now 5-6 times based on what my wife has told me the 2015 edge appears to use the TB15 throttle body from Rock auto. I hope to get a engine code to help troubleshoot, not a big fan of spending 300$ on a part and it does not solve the issue, but good info nonetheless thanks
2015 edge FWD 2 liter front rotor size?
Lincoln81 replied to Lincoln81's topic in Brakes, Chassis & Suspension
wow, guess nobody knows, ill measure them when I get home, then wait another 2 weeks to be able to put them on cheers -
looking at changing my brakes on my 2015 ford edge, I have 2 options for rotor size... without taking my wheel off as the car is 4 hours away from me for a week but id like to have the parts waiting for me when I get back home... does anybody know what size of rotor my 2015 edge FWD 2 liter takes? thanks folks
2015 ford edge non powered hatch issues
Lincoln81 replied to Lincoln81's topic in Alarms, Keyless Entry, Locks & Remote Start
this forum really sucks, im amazed how people don't reply -
I guess nobody knows -
hey guys, I have a 2015 ford edge with the non powered hatch, lately we have noticed that the latch takes a while to open, we press the bottom on the outside of the hatch 20 times before it finally opens, Also sometimes when we close the hatch it doesn't actually latch. Thoughts on issues? Latch? electronic button being faulty? everything is lubed, the latch itself appears to be functioning properly from what I've seen. I have googled this and most issues are with the powered hatch not opening and closing, mine is non powered so appears to be a different issue. any and all help is appreciated thanks
beauty, thanks Omar! cheers
hey everyone, hope you all had a great Christmas and best wishes for 2020! I made a post a little while back about a rattle, rattle is still there, ive troubleshoot as much as I could as I thought for sure the sound was coming from the inside, had the car up on multiple hoist at various dealers everything is nice and tight underneath, one mechanic sat in the rear while I drove with a electronic stethoscope as figures its the rear shock. although the shock appears good, no leaks, bouncing good ect.. so I have ordered replacement shocks for the rear to see if this will solve my rattle issue. Has anybody ever changed rear shocks on a 2015 or newer edge? any tips? tricks? I haven't been able to find any videos online. tons for the older gens Luc
my spare is a 17"... maybe different rim? winter wheels for these are expensive!
I ordered the part. ford wanted 900$ to install it. I did it myself, took less then a hour to pull old one and about a hour to put in the new one. bottom connection was the worst. really tight fit. no more check engine light. seems to be working ok for the past 19 days. Did a 1000km road trip plus in town. lets see how it works!
Hey everyone, we have a 2015 edge 2.0. Last week wife said she heard a noise lasted 20 seconds or so coming from rear of vehicle, day letter we got a check engine light, she didnt tell me till it cleared. I scanned it with scanner and got p1450, just today she heard the noise again and the check engine light came on again. Found this video on youtube This video describe my issue to a t. Is this common? Makes sense? The part number in the video is wrong for my edge but I have found Ford Part No.: F2GZ-9D289-A Tube Assembly - Fuel Vapour Separator is this the right part ? Will this solve my problem thanks everyone
Mike, I did not notice the rectangular drainage holes but I will take a look. I did investigate over the weekend, took the back plastic off, got inside while my son hosed the back of the edge and the water was coming in from the handle. I removed the handled and dried it, dried the outside of it and put some silicon on it, put it back on. let it dry and then tried to hose and no more water. While I was in there I put some rust control in a can to help keep it all good cheers
I haven't had a chance to look any further. It will be nice this weekend and I will wash it again and take a look
hey guys, got around to wash my new to me 2015 edge and when opening my hatch I noticed a water noise, moved the hatch back and forth and a bit of water came out of the latch area, then noticed the 2 rubber plugs/stoppers on either side and pulled them out and a few gallons of water came out... Where is the water getting in from? Is this normal? Bad seal somewhere? worried about winter going through a carwash and it freezing causing premature rust thanks
hey guys, just traded in my 15 fusion for a 15 edge. I have a set of nokian hakka R2 winter wheels 5x108 with 215/60R16 tires. Will these fit the edge? I know tires are not as wide or high as stock 18" but will it work??? Please advise Luc
I did the plugs on mine yesterday took all of 25 minutes. lost a 8mm socket but a very simple job to do on these - purchased vehicle used, has 57000km on it, slight carbon build up on it but piece of mind
hey everyone, just picked up a 2015 edge 2.0. and noticed there is a slight cut in the rear driver side seat belt. my kids are grossed out by it. Kids! I have called 3 different ford dealers for a quote for the part but most are useless. By chance anybody have a part number? thanks guys
New member from Toronto (Go Leafs/Raps/Jays/FC/Argos)
Lincoln81 replied to punman's topic in Welcome Forum!
Also you forgot about go rock. But they lost on Saturday. Raptors made up for it in Sunday -
Sounds good. I'll order new plugs and gap them and change them. Seems to be a fairly easy job. Anybody find a good deal on cabin air filter on Amazon?
I'll get pics when I get it all cleaned up. Been raining here all day. It's got a few small scratches I hope to buff out as well. Check engine light is off. It's got great power. I changed the engine air filter today. Old one was pretty plugged. Seems to be running better. I'll call dealer tomorrow to schedule trans fluid replacement and oil change. I also would like to change 4 inch screen to something better but these have limited options
Just picked up a 15 2.0 with 57k km on it. Works nice. Decent pick up. Comfy. I do however find the tranny shift a little hard sometimes. Besides that it's good. Mind you 3rd day I've owned it. 500km put on so far. How long have your turbos lasted ? Any issues ? Any other maintenace things I should know about ? Dealer put seafoam in when I picked it up to clean carbon. Check engine light is on. Said to wait a few days for it to clear... seeing on forums that seafoam or other products are bad for EcoBoost engines? All help is appreciated
Tesla style replacement radio
Lincoln81 replied to Brett Bazaar's topic in Accessories & Modifications
So when your booting up does it have radio? Or just nothing? Does your steering wheel controls still work? When you toggle between screens is it laggy? Any issues with Waze? Even with the nav being slow? What year is your vehicle? -
hey guys, welcome, I am new as well, just got a 15 EB. I am in Oshawa. -
bringing this back up. How has it been for the past 2 years? anybody else install one? I have a 2015 with the 4" screen and looking to add this. Please advise if it is worth it or not
