Ford_Owner
About Ford_Owner
Ford_Owner's Achievements
Hi everyone, Recently, I replaced the cover gasket of the bank 1 and performed the engine oil changed (5w20 as described on the owner manual), and when I started the car I got two codes P0340 and P0344 (using my ODB Scanner). Does anyone know where the camshaft position sensor is located and how to fix the problem? Thanks! P.S. Ford Edge 2014 Limited AWD
Last update!!! Hi everyone, After a smooth ride for 4 weeks, I got a misfire code recently from cylinder 1, and I found fluid in the spark plug #1 well, the color is almost the same as the coolant (Pinky) but it doesn't have a smell, I think some kind of water, I don't know where it came from, the other 05 wells were dry, any help would be appreciated! Thanks!
- 30 replies
- ford edge
- heistation
(and 2 more)
You mean there’s no EGR valve in my ford edge. That explain why I didn’t find it. Thanks!
Hi everyone, Can someone please help me locating the EGR valve for my Ford Edge 2014 V6 3.5L Limited AWD? I bought the Haynes Manual for Ford Edge but there's no location of it. Thanks!
Now I understand, thanks for your help!!
- 30 replies
- ford edge
- heistation
(and 2 more)
Hi, I cleared the code and it didn’t come back, I drove it for about 10 mins including highway and no code showed up. Any idea of what happened in the first place?
- 30 replies
- ford edge
- heistation
(and 2 more)
Thanks for the info !!
- 30 replies
- ford edge
- heistation
(and 2 more)
I’ll check it. Actually, the code occurred the third time I drove the car after gaskets and spark plugs replacement.
- 30 replies
- ford edge
- heistation
(and 2 more)
Hi, I have replaced the valve gaskets cover and spark plugs but now I got a check engine light with the code P1336, crankshaft position sensor, knowing that I didn’t touch that area, any help? thanks!
- 30 replies
- ford edge
- heistation
(and 2 more)
I hope it's the only thing I have to do, thanks for your help!
- 30 replies
- ford edge
- heistation
(and 2 more)
Yes, the spark plugs are too worn but the gap is pretty good 0.054 as recommended. I'm replacing the spark plugs and cleaning the extra oil in plug well. I'm thinking to replace the valve cover gasket too along with valve stem oil seals.
- 30 replies
- ford edge
- heistation
(and 2 more)
Do you think that if I replaced the cover gasket and the valve stem oil seals can solve the problem?
- 30 replies
- ford edge
- heistation
(and 2 more)
Can an overfill during oil change can cause this leak into plug wells?
- 30 replies
- ford edge
- heistation
(and 2 more)
Hi everybody, I got a big problem, I started to replace spark plugs then I noticed that one plug was literally immersed in oil, I don't know why, I have always respected change oil schedule and did it in a shop since it was bought brand new. Also I have noticed that two cylinders was open while the four others was closed. Please help me!
- 30 replies
- ford edge
- heistation
(and 2 more)
Thanks for your advice!
- 30 replies
- ford edge
- heistation
(and 2 more)
