CRJ
About CRJ
CRJ's Achievements
  1. Any advice on removing the emblen from the brake light housing?
  2. Thanks. What kind of gains do we get out of those down pipes? Would it void the factory warranty?
  3. Is there an exhaust kit out there, that gives us hp gains?
  4. He offered me 3 different options. OPTION 1: AXLE CALIPER FINISH DISC SIZE DISC TYPE Front 6-Piston M. Blue 355x32mm 3D Drilled, 2-Piece Rear 2-Piston M. Blue 350x29mm 3D Drilled, 2-Piece OPTION 2: AXLE CALIPER FINISH DISC SIZE DISC TYPE Front 4-Piston Red 355x32mm 3D Drilled, 2-Piece Rear 2-Piston Red 350x29mm 3D Drilled, 2-Piece OPTION 3: AXLE CALIPER FINISH DISC SIZE DISC TYPE Front 6-Piston Red 380x32mm 3D Drilled, 2-Piece Rear 2-Piston Red 350x29mm 3D Drilled, 2-Piece
  5. Today, I ordered a set of brakes from Loren. Did you do the install yourself?
  6. Thanks guys! 2018 sport. Tinted the front windows to match the factory tint in back. Purchased the grill on ebay. I was shocked that the whole grill was in gloss black, so I had the hoeycomb center painted in satin black. Had H&R springs installed. Wheels are Niche Misano in satin black. Tires are Coninental extreme contact 265/35/22. That's all for now.
  7. Thank you. I'm a new member, and have a little difficulty navigating through everything.
  8. On the first page of this thread, there is a picture of a silver Edge with aftermartket calipers and rotors. Could someone help me find out more about these, or piont me in the direction of the owner of that Edge? I'd like to do the same to my 18 Sport.
