Everything posted by flymore
What year/how many miles on your Edge? AWD? Good luck with the Subaru, they're very popular. A little scary for new Edge owners like me. ?
It was a nice day, about 60 degrees so I decided to crawl around under my new car. After a couple of short trips the temp of the PTU case was 196 degrees. The drain plug appears to be 1/4inch hex. I think someone posted it was 8mm, no way. 7mm way to big and 1/4 fits well with just a tiny bit of play. Do they make 6.5mm or is that to close to a 1/4? I don't have a 6.5mm in my set. It's really tight in there and still not sure I want to do this myself.
Sync 3 & CarPlay problem Arrgh!
flymore replied to timfountain's topic in Audio, Backup, Navigation & SYNC
The wifi in my new to me 2018 Titanium appears to work fine. Connected to my home wifi with my password and had it search for updates and none were found. However, I've only had this car a month so far so good. -
Assume you have a 2019? What engine? My 2018 3.5L AWD is not doing that. That's not good, take it to the dealer ASAP.
Got my window sticker here free with the vin, https://researchmaniacs.com/VIN-Number-Lookup/WindowSticker/Ford.html Am told this only works if the vehicle is at a dealer. Mine was a CPO bought from the dealer. Good luck.
Welcome, Got my window sticker here free, https://researchmaniacs.com/VIN-Number-Lookup/WindowSticker/Ford.html
I'm new to Ford and just recently purchased a CPO 2018 3.5L with AWD and enjoying it very much. You say the PTU failed at 150,000 did you service the PTU during it's life? If so when? Many recommend the PTU be serviced, but I discussed this with the dealer asked them to service the PTU but they insisted it doesn't need servicing till 100,000 miles. Fyi, my Chevy pickup 4.3L v6 drank some antifreeze most of it's life through the intake manifold. This is common. Just saying that if the antifreeze is disappearing it may not necessarily going into the crankcase.
Mine is the 3.5L PTU, probable similar to the 2.7L except the drain plug is not on the bottom but the side and it's smaller than T50. Hard to see what the fill side is don't think it's Torx. Still getting tools together for this. When I put the car up on ramps, it won't be level and not sure I can fill it properly. Temperatures here way cooler than middle east, was about 14F when I picked up the car couple weeks ago. thanks
What is the torque spec on the drain and fill plugs?
I've used Supertech in the past with no issue. You can search www.bobistheoilguy.com for comments or comparisons of oil. Mostly I use Mobil 1 now buy it when it's on sale.
So why didn't he just agree to change the fluid? Something like, "Yea I can change it for you. It'll cost you $xxx" was what I was expecting. Uhhh me customer? I mentioned how close the catalytic converter was to the PTU, and he said I could talk to one of his experts but it's good for a 100,000 miles. Guess I could try another Ford dealer. Not sure I want to do this myself, it's really tight in there. There was a post around here somewhere saying they changed their PTU on a 2017 AWD and the fluid looked fine at 29000 miles. I never know how long I'll keep a vehicle.
After reading the many posts here I talked to the service guy at the dealer about my new to me CPO Ford Edge PTU with nearly 29k miles on it. Not sure if you can see from the picture but there are paint marks on the drain and fill plugs so if one were to service this unit themselves it would probable void the warranty. I asked the service guy if it would be a good idea to change the fluid with summer driving coming up, he assured me no service was necessary on the PTU before 100,000 miles. He explained the most important thing was too keeping my tires rotated. Tires of different size would put a strain on the PTU. Thought this was interesting since my tire pressure was 34 psi left front, 32 right front, 30 left rear and 29 right rear. I adjusted all tires to 35 psi. Anyway I'm enjoying my new Edge. Cheers
I've only had my 2018 Ford Edge Titanium for a week. Bought it CPO with 28k miles, rear brakes look fine. Maybe replaced before I got it? Honestly, I hate rear disk brakes on cars wish they were drums. Twice I've had to replace both rear callipers on different vehicles because salt hits them and destroys them in the winter. They should just stuck with rear drum brakes!
Congrats on the new purchase. We're on our first Edge. It's a 2018 Titanium AWD, a little concerned about the PTO.
window sticker lookup for used Edge?
flymore replied to bamabob's topic in Buying, Leasing & Ordering
This just worked for me, https://researchmaniacs.com/VIN-Number-Lookup/WindowSticker/Ford.html Good luck -
Been changing oil for 54 years. Old man had a trucking company, no diesels plenty of dock highs and semis. Guss who did the work. Too cold to change now.
Hahaha no, Tuesday morning was 6 degrees...not wind chill. Normal temperatures should be in the 40's here in Ohio. Oh well. The climate changes 4 times a year here! No, I won't be changing the oil till it gets into the low 50's and I'll use 5w20 full synthetic. I'm not in a hurry, the oil looks clean. I think(hope) the Valvoline sticker was from the oil change before the dealer got it and did the CPO inspection. So the dealer didn't take the Valvoline sticker off the wind-shield and reset the OLM after they changed the oil! HAHAHAHA The miles on the Valvoline sticker was 3000 miles before the mileage was when I bought it. The oil that's in it doesn't have 3000 miles on it, way to clean. Oh well, we like the vehicle and think we got a good deal.
Saw this done to an Audi AWD on the Wheeler Dealers show with the car up on a lift. What he did was after the fluid was drained completely, pushed the syringe tight up against the drain plug and filled. Holding the syringe tight prevents spillage. Once filled he held the syringe tight with his right hand and the drain plug in his left. With a smooth motion, holding the drain plug up near the hole/syringe, pulled the syringe out and quickly moved the drain plug into it's place. Then just tightened up the plug.
I'd like to use 5w30, have some Mobil 1 left over from my Chevy 3.6l I'll probable sell to my buddy or use it in the wife's car. Funny thing, the Ford 3.5L uses the same oil filter as my Chevy 3.6L used, so those two extra oil filters I have are good!
Yea but the 946 is for the 2.0 and 2.7 litre not the 3.5 litre. Correct? I have the 3.5L so I must use the 5w20 not the 5w30. Correct? thanks
Yes, the WSS-M2C945-A is in my owners manual as well. So I think I'm ok too "fingers crossed" and I'll go full synthetic going forward. I'll save that valvoline link in case there's some question for warranty. It's not so much the burning of oil I'm concerned about, it's the wearing of those chain guides. When do you guys change oil? I've always used OLM in my GM cars. The GM dealer recommended changing the oil when the OLM gets down to around 10% and that's what I always did in my GM 3.6L. But the Ford dealer said they changed the oil and it's clean so I think they did, but didn't reset the OLM. Who doesn't do that!
Yea, that's what I'm planning on doing. Main concern is how the conventional oil may have caused wear inside the engine when Synthetic Blend is recommended by ford and GM and it may sound like this someday, Thanks
How do I get the bottom cover off to get to the oil filter and drain plug? Thanks
I can only hope the oil was changed "frequently" up till now. Hence the risk of purchasing a used car. The oil looks clean right now, so it appears it was changed at the dealer and they didn't reset the OLM. I''ve always used the OLM in my previous cars, so why not use it now? Yes, 3.5L.
Bought a CPO Edge over the weekend and enjoying it. Two problems, 1st, Noticed a windshield a sticker that said Valvoline conventional oil change about 3000 miles ago. Manual says, "Recommended motor oil (U.S.): Motorcraft® SAE 5W-20 Premium Synthetic Blend Motor Oil XO-5W20-QSP" So whoever had this vehicle before me used conventional oil! ? 2nd, After the test drive noticed the oil percentage down to 39% so asked about an oil change at the dealer... salesman said, "oh they just didn't reset it". Really! Picked the car up a day, they were going to reset it... now reads 37%, so they didn't reset it. The oil looks clean, but the oil monitor now reads 36%. I'm thinking I'll change it when it gets down to 10%. What kind of damage was done to this engine running conventional motor oil through it the first 28,000 miles? I'm intending on keeping the vehicle. Thanks
